Will a disc player barn rot from lack of use?
How should one be stored long term?
    F1nut Posts: 49,799
    Upside down in a dark, damp place.
  • afterburnt
    afterburnt Posts: 7,892
    So I should hang it next to me in my bedroom?
    F1nut Posts: 49,799
    Yes
    pitdogg2 Posts: 24,576
  • verb
    verb Posts: 10,176
    edited April 2018
    Humidity control is the key here. I would say used a sealed bag with some desiccant if you have it, to prevent corrosion of the metal components.
    Any drive belts, especially the older variety, suffer from dry rot of some sort, so special care is needed there.
    I did neither of those on some older players that I have. Just stacked em up in the corner of the basement. After years, a little hint of corrosion on the bottom of the chassis appeared.
    Oh yes, and get it out of the barn!
    Live and Learn! :smile:
  • Nightfall
    Nightfall Posts: 10,071
    I wonder if one of those food vacuum sealers would have large enough bags for stereo equipment.
    afterburnt wrote: »
    Village Idiot of Club Polk
    mhardy6647 Posts: 33,043
    edited April 2018
    sort of. Some of them have rubber belts that drive the drawers. Those belts don't age well.
    Otherwise, they're fairly robust IMO. The optics might get dusty/grimy/mildewed. The lubricants (tray glides, e.g.) may get galled up.
    Avoid damp places but not too hot, not cold and not too dry are also probably best practices. :)
    That's what I've got.
    Viking64 Posts: 6,684
    The best solution is Dynamatting all flat metal surfaces and smothering all board components and the entire transport mechanism with hot glue.
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    How'd that work out for ya? :smile:
    verb wrote: »
    Great!
    barn rot intensity level = zero
    That reminds me, there is a 1958 Telefunken stereo console in the barn chock full of vintage spare tubes still in boxes. I need to go have have another peek at that. :p
  • kharp1
    kharp1 Posts: 3,453
    Viking64 wrote: »
    Do tell...Can I place myself near the front of the line if you decide to part with some, or, all of them???
    kharp1 wrote: »
    Duly noted. Although I don't see myself as someone that is going to package and ship tubes any time soon. :p
  • afterburnt
    Nightfall wrote: »
    That gives me a great idea (great for me) I am gonna get some of them vacuum bags that you put clothes and carp in and vacuum the air out of. That should keep it sort of inert.
  • kharp1
    kharp1 Posts: 3,453
    Viking64 wrote: »
    kharp1 wrote: »
    Ya bum! :)
  • afterburnt
    I should maybe pack my whole HT system in cosmoline?
    Clipdat Posts: 12,602
    Make sure you put your remotes in ziplock bags too while you're at it.
    TV-REMOTE-in-bag.jpg?resize=800%2C600
    afterburnt wrote: »
  • afterburnt
    They are already tagged and bagged
  • Kingrat
    Kingrat Posts: 74
    I've had a couple of computer DVD burners have issues after sitting for years unused. Both were Sony drives in other brand burner chassis. They both burned coaster after coasters, and after playing a CD in them, it was obvious why. Both had lasers that weren't tracking well at all, I'm guessing the little servo motor that adjusts the laser was gummed up. "exercizing" the laser by continuously playing a CD got both of them sounding, and burning, ok. But they later (several months) both failed totally. As cheap as they were, it didn't shock me. I think they were both about $20 each, with Nero!
    Cable atheist: They're just trying to get your money like a TV preacher!
    Vinyl system: I'm long done with the snap, crackle, and pop.
  • afterburnt
    The optical drive in my laptop died from lack of use.
  • verb
    verb Posts: 10,176
    afterburnt wrote: »
    Among other things, ahem! :smile:
  • afterburnt
    No, that ran away
