Speaker Front Options
This may sound like a crazy question but has anyone done something different to their speaker fronts? I mean, I'm use to my Klipsch Coppertone cones which I almost never cover with the grills. Black drivers on a black front gets kind of boring to me. I realize the drivers can't be painted but what about different finishes on the front panel. Would a thin copper veneer on the front panel cause any acoustic issues ? Silly I know but just wondering if there are any ideas out there for the Vintage Polks.
Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
    txcoastal1 Posts: 13,132
    Hey, they're yours. Like you mentioned you're in it for the long haul
  • ThomasD
    ThomasD Posts: 260
    Don't have the SDA's yet but will be working on the 7's and just haven't seen anything other than black on black vintage fronts.
  • verb
    verb Posts: 10,176
    ThomasD wrote: »
    Some guys here used different colored cloths for the grilles and fabric side panels. Others used different veneers, or solid wood side panels and endcaps. The possibilities are endless!
  • ThomasD
    ThomasD Posts: 260
    I was thinking about veneering the fronts as an option when I do the cabinets. Also wondering if the fronts of the TL tweets can be removed. I'd consider having the main plates of the SL3000's anodized. I see the screws but don't want to separate until I know they can be safely removed.
    F1nut Posts: 49,800
    You do NOT want metal on the front bezel of your speakers or your tweeter bezel. That would present a very different sound and one I don't think you would like.
    F1nut Posts: 49,800
    Smallies wrote: »
    If they are SDA2's I say steampunk the crap outta' them, really boring looking speakers.
    Why is it you never have anything productive to offer?
  • ThomasD
    ThomasD Posts: 260
    My bad and my ignorance. I just opened up the SL3000's and looked at my SL1000/2000 tweets. The heft of the magnets threw me. I thought they were metallic fronts. May just consider very carefully painting them. I'm really bad at leaving things 'stock' looking, like to add a custom touch. Thanks for bringing that to my attention. By the way, F!nut, looks like I've got you on a couple subjects at the same time.
    F1nut Posts: 49,800
    It's your lucky day, I'm in a good mood.
  • westmassguy
    westmassguy Posts: 6,850
    Try dressing them up with some nice chrome or nickel plated cap screws, along with Hurricane Nuts. Once the woofers and PRs are cleaned properly, they're rather nice looking.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • ThomasD
    ThomasD Posts: 260
    Actually, just ordered SS, socket head capped, Allen head drive screws w/ H-nuts from Amazon. Trying to track down the sound dampening material to get that ordered this weekend.
    xschop Posts: 4,698
    Full metal baffle gives a slight increase in midrange output. Dizzy Gillespie would approve.
  • ThomasD
    ThomasD Posts: 260
    xschop wrote: »
    Am I being 'ribbed' ? Or are you talking something like the JBL Monitor baffles?
  • verb
    verb Posts: 10,176
    ThomasD wrote: »
    xschop wrote: »
    Yes ribbed dude! All in good fun! Lot's of jokers, ahem, children here! :smile:
    F1nut Posts: 49,800
    xschop made aluminum baffles for a pair of his speakers, I don't think he's ribbing you.
  • ThomasD
    ThomasD Posts: 260
    Hmmm..... did he do a thread on it?
    F1nut Posts: 49,800
    Of course. I still don't recommend doing it as that will create a highly reflective baffle, which is the opposite of what one wants.
  • ThomasD
    ThomasD Posts: 260
    I understand. I know the JBL's are designed with them. I was just wondering how they looked. B)B)
