New polkie
mn_polk_guy
Im new here from minnesota and just scored Sda 2bs for $300 with cable, i love them. also scored some 7s for 60 bucks, which i love as well.... And 2 pair 10s...a pair Rta 8tls (my first polkies) and a pair of 5s and 5jrs... Can say im addicted.. Just stopping in to say hello! Will be doing alot of resto and mods in the future but for the time being every pair is functional and appear to be original.
Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
7s and sdasMonitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
All the others.. Not actual listening placment for any of theseMonitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Im In an apartment right now, moving into a house may 1st.Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Nice family, congrats on your purchase and good luck with the move2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Welcome to the jungle, the rabbit hole, the endless time suck...... we are that and so much more....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Welcome to Club Polk! I joined back in December with a set of 2B's as well. Since then, I now have 2 sets of 1C's one stock except for the tweeter upgrade (easy to do), and another WIP fully modded set! Oh yeah my 2-channel rig is completely transformed with the help of Polkies!
Lot's of roads to go down with your 2B's - have fun!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Welcome to the forum!
Welcome!
Last Nov a Polkie from Minnesota drove to the Detroit area to buy my 2.3TLs. We loaded him up and he drove home same day! He goes by PKQUATAC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Welcome!
Wow! And I missed them by just a month!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
So on one of my sda's i have a pin hole in the passive. Can it be repaired or should i find a new one?Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Picture of my passiveMonitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Appears i may have some dry rot... Damn.Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Fix itGustard X26 Pro DAC
Repair it. If you can reach it from the inside, scuff the surface and apply a rubber weld with a q-tip. The repair will be invisible. The weld should contact the fissure walls as well as the stuffed surface. Use as little as is necessary.
I pulled it just to peak. looks repairable ill give it a shot...and keep an eye out for an extra 121.
Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B. -
Rubber weld as in bicycle tube patch glue?
Any brands? 3m scotch weld?Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Welcome, mn_polk_guy, to Club Polk, form another MN Polkie!
I think I may have seen those 2Bs recently on CL(?). Are they the pair with the minor water stain on the top end cap?
You look like you got well down into the Polk rabbit hole prior to your arriving here. I did it the other way around, just had my Monitor 10Bs before joining. Since then, I've got Monitor 7 (IIs), 5Jr+s, VM10s (surrounds), CS400i (x2), SDA-1Cs, LSiM703s and a pair of DSW-550i subs.
AND...Monitor 7Cs, 4s, 5Jrs; RT12s; VM30s, 20s and 10s; LSi7s, 9s, FXs and 15s; R50s; PSW10 and 110; RM8000Ts, 7300Ts, 7302s; DSW-3000 and 2000, etc., etc. have all moved through here at one time or another, to name a few. -
Yup! Designed to repair neoprene and vulcanized rubber and remain flexible. -
Yes thats the pair, guy almost didnt part with them. Everything functions great but will need some refinishing. Im supposedly the third owner of the pair.Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
I use this stuff at work for tire patching(car tires).Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
I'd ask a local bike shop what they recommend first...
