Signature S 55 with CsiA6
I am currently running the CsiA6 with Rti A3`s.
Can pickup a pair of S55`s for a good price.
Would I notice a big difference? I do not want to replace the CsiA6 either.
Any comments would be appreciated.
Only your ears will tell you if you like the combined sound of the 55s and the CsiA6. Try it and see.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Good advice. Problem is I can not return the speakers if I dont like them.
I'm pretty sure you will like the Signature 55s, they aren't as bright as the CsiAs and do well with both music and movies. Or you can look for a deal on the 55s elsewhere. It seems like someone is always running a special on them.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
They will not be timbre matched, so yeah you will notice.Political Correctness'.........defined
President of Club Polk -
The deal fell through.Thanks for the advice though.
Yes they are not timbre matched but it will blend very well.
I have a CSi-A6 with my S60, it blends very nice. I've tried 3 different center speakers with my current setup. S30, TSX250c and CSi-A6. Out of the 3 I like the A6 the best. Dialog is very clear with a nice rich detail the other speakers missed, mostly the TSX250c.
