ARC HDMI
Oppo 203 has a dedicated audio only out HDMI. Can this be connected to the ARC HDMI?
Best Answer
    tonyb Posts: 32,906
    Answer ✓
    wapfunz wrote: »
    Sorry - can the oppo dedicated audio out be connected direct to the Magnifi Mini HDMI arc in port? Is the ARC trigger required for the Magnifi Mini. The OPPO connects to the ARC HDMI on the TV for video and Audio, and I use optical from the TV to the Magnifi Mini. So the HDMI in on the Magnifi mini is not used. As the Oppo can bitstream SACD and DVD-A, I was hoping the dedicated audio only HDMI out could be connected to the Magnifi mini HDMI.
    If I'm not mistaken, yes you can connect the oppo to the sound bar using HDMI, but if the purpose is for SACD, I'm not sure the sound bar can decode that. It may process down the signal, but then whats the point.
Answers
    F1nut Posts: 49,802
    The ARC HDMI connection goes to your TV. You want to connect your oppo to one of the HDMI inputs on the back of your AVR.
  • wapfunz
    wapfunz Posts: 3
    F1nut Posts: 49,802
    Ah, that I've got no idea about.
  • wapfunz
    wapfunz Posts: 3
