Where to go from here?
Hello guys..thanks for having me.
I've been putting my system to gather for a while now, and am now looking for a receiver to power it all.
I currently have the following:
RTIA7's for fronts
RTIA5's for rears
RTIA1's for surround
CSI3 center
PSW125 powered sub
All powered by a Pioneer VSX 1027 (165w x 7) via 16g wiring.
I'm pretty sure I'll need to push the speakers harder. Not sure what receiver is a good choice in the 2000$(CAD) market. Any input would be much appreciated. I'm pretty new at designing a proper system, I've always just hooked up the speakers and just placed them where they fit in the room. Over the next year or so I plan on putting a games room in the unfinished basement with a theater-like setup in one half of the room. So placement will be thought out a little better in its new space.
Any suggestions? Can I use the preout to run speakers from a 2nd AVR? Or should I replace my receiver, add an amp? Thanks for your help!!
Best Answers
  • TheaterBeaterTheaterBeater Posts: 6
    Accepted Answer
    Yes..i think your right. Underpowered for sure. Just got the a7s and a1s..havent tried to push them yet. I have a couple pre outs on this receiver. If I add an amp for the fronts and center, would that help push the a5s as rears?
  • gudnoyezgudnoyez Posts: 6,158
    Accepted Answer
    I have A9s and a CSIA6 powered by a 3 Channel amp, A3s, and A5s some times swap the A5s with FXIA6, powered by the AVR. I also run dual PSW 111s. Look for a receiver with preouts and get a 3 or 5 channel amp. I think its possible with your 2000 budget if you look on the used market.
    edited March 24 Accepted Answer
    If you got preouts on your receiver and 2000 CAD, that's like what 5000 in American dollars? :D Look for Parasound, B&K, Adcom. Outlaw Audio has some good prices on new stuff, not sure what you have for an AVR, but put a Amp on the front three and you should be good.
    Post edited by gudnoyez on
  • mlistens03mlistens03 Posts: 986
    Accepted Answer
    Your AVR doesn’t have pre outs, so I would suggest getting another AVR for your preamp. I would look at Yamaha, Pioneer, Older Denon or Marantz if your willing to go used (not sure what their new stuff is like, or if it’s any good), anyone else want to chime in? Whatever you get, make sure it has full 5.1 pre outs.
    For separate amplifiers, I don’t know a ton about them, so I will let others help in that area.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
Answers
  • So..if I were to spend 2000$..what would I buy?
    Yamaha’s aventage line up is supposed to be pretty good, I would suggest looking at that.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • Is it possible to get both for 2 grand? I can't seem to find a decent AVR (with ATMOS) and a power amp in this budget..lol
  • ClipdatClipdat Posts: 3,450
    Hit up A4L for a refurb AVR.
    Got Dayens?
  • Thanks clipdat..i found the yamaha set yhere. MX-A5100 AND THE CX-A5000...but they will destroy the budget. 11.2 is bigger than I was thinking, but would allow room to grow. They also have a few marantz Act's. I've not had one before..
    At the risk of embarrassment..whats the difference between a normal AVR and an Integrated amp?
    AVR stands for Audio/Video receiver, a integrated amplifier usually doesn’t carry video... I think. I might be wrong lol
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • FestYboyFestYboy Posts: 2,317
    An integrated is an all in one for audio signals it houses an amp (obviously), source switch for multiple inputs, pre amp, volume control, and sometimes a tuner.
  • Any other sites like accessories4less?
Howdy, Stranger!
