What’s the best way to clean pearless tweeters on monitor 10a
Thataxeguy
So I bought some really good condition moniter 10a’s for $70 and the guy threw in a polk center channel and a psw202 sub. Wich in my opinion was a amazing deal. On the 10a’s the tweeters are dusty and the one tweeter has a indent on it but still works. How should I clean them without damaging them and how should I try to fix the other one.
Post edited by Thataxeguy on
Best Answers
Ok, I don't think there is anything you can do about the crease. As for the dust, if you have a vacuum with a round brush nozzle that should work. Don't actually brush the tweeter, just put the mouth of the brush over the tweeter. To clean the drivers and PR you can spray original Windex on a soft cotton cloth, then wipe in a circular motion until clean.
You need to get the speakers off the floor. The tweeters should be at ear height.Political Correctness'.........defined
President of Club Polk -
The original Polk stands have a 5 degree back tilt and were short. However, that was only because Polk didn't want to offer stands that made the speakers look like big floor standers. Therefore, you don't need nor should they have a back tilt if you get stands that raise the tweeter to ear height.Political Correctness'.........defined
I've used Fantastic and a Q-Tip to clean the dome on the Peerless many times. You can try a hair dryer on low heat to soften the dome, and possible smooth out the crease, You can also use a cap from a prescription bottle to protect the dome, if you want to cleanup and paint the face. Certain size caps will fit perfectly in the recess where the dome attaches to the faceplate. Be sure to hold the cap in place while you spray the faceplate.Home Theater/2 Channel:
dhsspeakerservice.com/
Answers
A few pics would help.
BTW, it's Peerless.Political Correctness'.........defined
Picture of the tweeter or speakers
Thataxeguy wrote: »Picture of the tweeter or speakers
Both, especially the tweeter
By the way welcome to Club Polk2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Thanks for the advice, I’ll give it a shot. As for getting them off the floor I’ve been trying to find some stands or I was gonna build some.
Thataxeguy wrote: »As for getting them off the floor I’ve been trying to find some stands or I was gonna build some.
Build them, factory units tend to be a bit flimsy. Oh, don't forget to give the top plate a 15°(?) tilt upward. -
Here's a drawing for the stands
That should be 5 degrees.Political Correctness'.........defined
Build them, factory units tend to be a bit flimsy. Oh, don't forget to give the top plate a 15°(?) tilt upward.That should be 5 degrees.
I knew there was a 5 in there somewhere
