BMW question
vmaxer
vmaxer Posts: 5,116
Need some quick advise guys.
I am looking at a used 2009 BMW X5 3.0 - original owner, good car fax, single owner - 48,818 miles. Anyone have a reason I shouldn't buy it??
Planning to meet the owner Friday morning.
So, need info quickly.
Thanks in advance.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
«1345
  • FestYboy
    FestYboy Posts: 3,861
    Well, I could say it's a BMW and that's reason enough to avoid it, but that vintage has dash display issues and coil packs start to fail around now (if one goes down, replace them all at the same time). If the headlamp lenses are crappy looking, do not try to polish them, it doesn't go well. Replace or clean and clear coat.
    Then there's the offset rubber and it's associated cost.
    I could come up with more but, meh...
    On the plus side, it's a BMW. They do ride nice, quiet and have better than average power.
  • vmaxer
    vmaxer Posts: 5,116
    Well, not sounding so great....
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy
    Looking for an SUV? See if you can find a land cruiser... Hard to beat Toyota reliability...
  • vmaxer
    vmaxer Posts: 5,116
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,116
    What's it worth??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy
  • vmaxer
    vmaxer Posts: 5,116
    FestYboy wrote: »
    Which one?
    This one.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    nooshinjohn Posts: 25,093
    I wouldn't look twice at a BMW. Here in L.A., it seems everyone has one, and their recent reliability has not been the best. there is so much waiting to break on it that it will shock you.
    But I drive a Jag, so my advice should be taken with a grain of sea salt.
    txcoastal1 Posts: 13,132
    @vmaxer
    What's your daily avg driving it....???
    It's Chrysler that screws that one up... My Jags have all been fantastic.
  • FestYboy
    vmaxer wrote: »
    FestYboy wrote: »
    Which one?
    This one.
    FMV from my area probably wouldn't translate well for you. Have you checked for local comps?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    I absolutely loved driving my 2008 535xi.
    I absolutely hated my maintenance shop options.
    I absolutely hated that every problem required 10 more steps to solve than a "normal" car.
    Case in point, the battery. Sure, you can buy a "normal" battery at Autozone or what have you. But then there is the 1 service hour for the dealer to "reset" the computer so that the charging system doesn't kill your shiny new battery.
    The premise is, as the battery ages, the computer adjusts how the battery is recharged so as to prolong the life of the battery.
    Even something as simple as the single frame wipers were a pain in the arse. You had to get the actual BMW branded Bosch wipers or the aftermarket options would hit the hood edge when they went to full rest. And of course, BMW charged about 200% more than the aftermarket models.
    The 535 has something like 53 different computers. All potential failure points along with all of the associated systems.
    I had Jag charge me (actually the shop that redid my headliner) 247.00 to replace a blown fuse.
  • vmaxer
    vmaxer Posts: 5,116
    Well, not what I expected - how are they still in business?? I have discussed with a few local BMW owners and got good reviews - not sure what to do... :'(
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Go with your gut, but know that if you pay ten grand now, you will be spending another ten over the next two years...
    That's why i asked how many miles a day/year will you put on the car.
    Fancy cars are like a lot of hot women, fun to drive, but it'll cost ya' ;)
  • afterburnt
    afterburnt Posts: 7,892
    Overheard BMW owners conversation "You know how they fall apart after five years" "yeah you got to buy another before that" I dunno but it sounded pretty stoopid to me. I guess if you are made of money they are nice. I had a few Mercedes but I always got rid of them when the warranty was about up. Yeah that was pretty stoopid too. At any rate I found that you dont get your monies worth unless you can drive em at close to 100 mph otherwise they are pretty much just another car. But 100 mph never felt so slow!
  • vmaxer
    vmaxer Posts: 5,116
    txcoastal1 wrote: »
    Probably 10,000 or so a year. Certainly not made of money.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,116
    Can’t afford that.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    There's your sign, unless you get serious brownie points with wife/GF....just sayin' :)
  • vmaxer
    vmaxer Posts: 5,116
    edited March 2018
    txcoastal1 wrote: »
    Wife has been gone since last September, no plans to let her come back.
    Was going to let my 17 year old daughter use it.
    She lives with me.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy
    Land cruiser.... For you.
    Your daughter can buy and destroy her own car.
    Or if you're set on getting one for her, get something with a manual transmission.
  • FestYboy
    Expensive Nissans...
  • Joey_V
    Joey_V Posts: 8,518
    I would not buy a used Beemer. But that's me.
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited March 2018
    I work on these things daily, Love driving them, hate fixing them. The X5 is the worst BMW there is. JUNK! The cars aren’t so bad, but high maintenance. Just did 6 injectors on a 335i today. 480$ per injector x6, not including labor, 156,000kms on that guy.
    Unfortunately their interiors are kind of bland unless you want to spend big money on the good stuff...... M series. Really love the inline six twinturbos, absolutely awesome engine, except that they get this wastegate flap rattle around 120,000 km’s, then the underboost faults come after that, then 2 new turbos..did I mention these things piss oil? Seriously it’s ridiculous.
    2 channel:
    Theater:
  • Jaybeez
    Jaybeez Posts: 748
    I had a used 740iL with about that many miles. Impeccably cared for. Over the 2 years I owned it I spend $5K fixing stuff. I called it the "$800 wonder" because it cost at least that much to fix it every time I took it in.
    If I was looking at a car like that I'd take an Audi Q5 10 out of 10 chances.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • mikeyb128
    X5’s roll up to the shop and we all start yelling “not it!”
    2 channel:
    Theater:
    mikeyb128 wrote: »
    Sounds like a mad dash to the restroom just to say...not it
    @vmaxer , got your answer, or do I need to have Nancy Reagan "just say no" again?
