Do I need a sub with these Usher MD2's?
Thinking about a PB16 Ultra :#
    Clipdat Posts: 12,601
    What kind of music do you listen to?
    txcoastal1 Posts: 13,132
    Get you a pair of Rhythmic F12SE's :)
    http://www.rythmikaudio.com/F12SE.html
    EndersShadow Posts: 17,531
    Yes.
  • afterburnt
    afterburnt Posts: 7,892
    edited March 2018
    Clipdat wrote: »
    You name it, I listen to everything that's not new like techno, screamo etc.
  • afterburnt
    @EndersShadow these things go pretty low, how would it be beneficial to add a sub?
    Sent you a test mix :)
  • afterburnt
    afterburnt wrote: »
    Clipdat wrote: »
    That was as clear as mud. I do not listen to new stuff like techno and screamo. I would like to be in a screamo band though.
  • afterburnt
    Clipdat wrote: »
    @Clipdat thanks, I will have to figure out how to play that as I am disconnected from my PC and other portable devices except my Gorgo pad, but that's only a controller. I wouldn't know how or have any desire to steam music from it. After all it is evil.
    It might be techno though. lol
    afterburnt wrote: »
  • mikeyb128
    mikeyb128 Posts: 2,885
    Yes you need a sub. I love my JL in my 2 channel system. Once you have a sub, you will never go back!
    2 channel:
    Theater:
  • afterburnt
    edited March 2018
    Specifications:
    Dancer Mini-Two diamond
    2-way system : Diamond DMD dome tweeter 1.25″ ,
    mid-low woofer 7″x2 (8948A),
    sensitivity: 90 dB @ 1 watt / 1m
    nominal impedance: 4 ohms
    frequency response (-3 dB): 28 Hz ~ 40 kHz
    power handling: 100 watts
    crossover frequencies: 2.7 kHz
    I am running them with Dayens mono blocks, if you think I would benefit from running a sub it would have to be an itty bitty one.
  • Mikey081057
    Mikey081057 Posts: 7,127
    An SVS SB2000 would do the trick nicely.
    Garage | Polk Monitor 5B's
  • afterburnt
    edited March 2018
    DSkip wrote: »
    How many hours on them so far?
    The Ushers? Damn near 24/7 365
    My company pays my light bill in CA
    Everything is rub in unless it needs 500 hours
  • Derf
    Derf Posts: 229
    afterburnt wrote: »
    txcoastal1 wrote: »
    DSkip wrote: »
    I think if you haven't yet, room treatments should come before a subwoofer . . .
    Just this week I ordered room treatments and a Rythmik F15HP. I'll let you know how things turn out with my MD2s. I know I definitely need the treatments.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
  • Derf
    Derf Posts: 229
    Rythmik F15HP added with MD2s last week. I'm using high level inputs as recommended by some here, so I called Wireworld and had them make one cable for me to match the speaker cables I have. Works perfectly.
    @afterburnt I'm glad I put this in my system. YMMV but for me adding a sub with the MD2s now gives me the overall sound I was looking for.
    Speakers: Usher MD2
  • afterburnt
    @Derf Wow I would love to hear your system, good stuff there. Why did you choose that particular sub?
  • Derf
    Derf Posts: 229
    afterburnt wrote: »
    I was thinking of a REL, mainly because of the high level input, but Ron @txcoastal1 said to check out Rythmik. Since Ron sold me the Ushers I figured he knows the sound signature of the speaks, so after researching, and seeing others on the forum also recommend Rythmik, I decided to go with it. Figured I'd defer to the experience of the masses, since mine is limited. I'm loving it. It gives the low end I feel was lacking. I listen at a relatively low level all evening long, and I wasn't getting much bass at low levels. Now, it's there where I wanted it. And when I do turn it up, WOW, it rocks the place. And as I have seen others say, it is as if the bass is coming from the speakers, not the direction of the sub. Highly recommend it.
    Speakers: Usher MD2
  • afterburnt
    @Derf, thanks man! I will have to fire up the printing press and ink up the rollers.
  • afterburnt
  • afterburnt
    I ain't got no money that I can depend on. Anyone think an SVS SB1000 will do the job when I cash in my bottles and cans?
  • rpf65
    rpf65 Posts: 2,127
    Are you asking people to think on this site?
    Shame on you.
  • afterburnt
    How bout two, or should I be looking for a big bad better ONE?
  • mikeyb128
    I would take 2 lesser rythmics over the one svs sb16.
    2 channel:
    Theater:
  • afterburnt
    mikeyb128 wrote: »
    @mikeyb128 Model?
  • Derf
    Derf Posts: 229
    txcoastal1 wrote: »
    Speakers: Usher MD2
  • afterburnt
    Derf wrote: »
    txcoastal1 wrote: »
    HEY! Where did he write that? I don't think I can get half a pair!
  • afterburnt
    I am going to try to try an SVS SB1000. Can I just use some "decent" cables since they wont be carrying a lot of current?
  • Derf
    Derf Posts: 229
    afterburnt wrote: »
    Check out the Outlet section on the SVS website. Might save a few bucks.
    Speakers: Usher MD2
  • afterburnt
    Derf wrote: »
    afterburnt wrote: »
    @Derf, I am not ready to buy it just yet but I see some cables on sale that I can get now. I am figuring that the cables can be a lower grade since they don't carry much current. I could be wrong???
  • Derf
    Derf Posts: 229
    afterburnt wrote: »
    If I've learned one thing around here it's that everything in the chain matters. I would think using a cable that is of the same quality, or has the same sound signature, as your speaker cables would be a good place to start.
    Speakers: Usher MD2
