Lightning ds freezes
Pretty much happens 50% of the time when I turn off the Satan ipad 2 mini. Does anyone else have this problem?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    edited March 2018
    You seem to have a truly passionate hate for Apple products, why not just move on to another tablet? I don't get it...
    I hope it's a fluke, I just bought an Auralic and am getting it set up now, having to futz with a broken app doesn't sound like something I'd stick with
  • afterburnt
    afterburnt Posts: 7,892
    edited March 2018
    @AsSiMiLaTeD you can only run it with ios
    Btw I hate everything
  • afterburnt
    Furthermore this glitch is kindda new, started with one of the last updates of ios or lightning
  • AsSiMiLaTeD
    Seriously, their software only runs on iOS?
  • afterburnt
    edited March 2018
    Yep, thus my Faustian bargain
  • afterburnt
    Oh you can run the Auralic with something else but lightning only runs on ios
  • mikeyb128
    mikeyb128 Posts: 2,885
    I was using an Auralic mini with an IPad Air and it was flawless. Since switching to the Aries Femto, with the same IPad, the app crashes at least 50% of the time. It seems to have nothing to do with the iPad, it is only the app that freezes then crashes.
    2 channel:
    Theater:
  • afterburnt
    Apple is still digital evil
  • mikeyb128
    I tend to have a long listening session on Friday, iPad is set to only go to sleep with the cover closed. The app will freeze in mid operation.
    2 channel:
    Theater:
  • afterburnt
    I think I have auto update on so I'm not sure if its lightning or the prince of darkness
  • Hermitism
    Hermitism Posts: 4,205
    afterburnt wrote: »
    Sell me your Auralic Aries Mini for super cheap and your problem will be solved. In fact, you should pay me to take it off your hands. :smiley:
  • AsSiMiLaTeD
    afterburnt wrote: »
    Still don't understand why you continue to use a product you hate so much, Samsung makes a great tablet as well try them out.
  • AsSiMiLaTeD
    edited March 2018
    OK I have a question for those using the app. This is gonna seem stupid but it's also gonna be a deal breaker for me if I cannot figure it out.
    I want to browse my music by Genre > Artist > Album. So when I hit the genre filter and select a genre I'm expecting to see a list of all the artists, then I hit an artist and get their albums. This is the way JRiver and every other piece of intelligently designed library interface I've ever seen works.
    Instead, by default, it does the same thing the idiotic default Apple Music app does...which makes literally zero sense to me. I select a genre and it shows me a list of albums in that genre, in order by album name. That seems completely nonsensical and is totally backwards from how I listen to music. I want to hit the Prog Rock genre, scroll to Steven Wilson, then see his albums instead of of having his albums thrown in a list of everyone else's...I really do not understand this design choice.
    Can I make the Aries work the way I want?
    Post edited by AsSiMiLaTeD on
  • WagnerRC
    WagnerRC Posts: 2,139
    my is only a problem as skip mentioned. changing programs or going to sleep. Overall super happy with the aries
  • AsSiMiLaTeD
    Appreciate it, I’ll see if I can figure out the JRiver setup...I should also try Roon again
  • afterburnt
    edited March 2018
    afterburnt wrote: »
    uh because it controls my Aries
  • afterburnt
    Hermitism wrote: »
    afterburnt wrote: »
    never
  • AsSiMiLaTeD
    See Skip's comment above, you can also use JRiver or Roon
  • afterburnt
    I already told you that you can run it with other stuff
    gudnoyez Posts: 8,066
    edited March 2018
    I won't diss Apple products have a few IPods and a IPad, but I like to keep it Simple. I use a couple of Chromecast audio's going through the Oppo's Dac, the Marantz's Dac or the Musical Fidelety M1 with a couple of Samsung tablets, and Galaxy phones. It's easy and hassle free and sounds good to boot. It's less time messing around and more time for the Tunes.
  • AsSiMiLaTeD
    has anyone here gotten the Aries to work with JRiver, and if so can you share the steps? I've set the Aries to a UPnP Rendered, which means it should show up in JRiver, but does not, I've been at this all afternoon and cannot figure it out...any help is appreciated
  • afterburnt
    Voltz is probably running his with J River.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Maybe Father Merrin can help you?
    Garage | Polk Monitor 5B's
  • afterburnt
    No need for an exorcist it's just s nusome. I was just asking. I am actually glad to have such first world problems.
    mhardy6647 Posts: 33,046
    The title of this thread made me think of this. Since I now can't get it out of my head, neither will you be able to, either.
    https://youtu.be/xsJ4O-nSveg
  • Mikey081057
    So if you had the ROON app I think you would be able to control the Auralic with a non-Ios device.
    You can try it for free.
  • afterburnt
    That Roon looks cool but I have a learning disability. I don't think I could learn how to use it in fourteen days. Anyway that Lightning glitch is just a newsome it doesn't really bother me. If someone has a fix great if no one has a fix great.
