FS: Raspberry Pi based streaming unit
stangman67
Hey polkies,
Selling a little streaming unit I put together a few years ago. It is a raspberry pi+ with the IQ Audio Dac+ add on in the iqaudio case. Right now it has volumio running on it. Nice sounding little setup. Has onboard Ethernet and a WiFi usb dongle as well. Has some scratches and signs of use etc, it’s not supposed to look pretty, just sound good
Asking 50+ shipping. Will require you to have a usb keyboard to set up WiFi in your home . This is not a plug and play type deal, you need to be willing to spend a bit of time in the menus setting it all up, if I can figure it out, you can too!
does it have a digital out on it? Can't tell from pics on my phone.
No digital out. The dac is connected via output pins on the PI itself. The dac is excellent though.2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Could I run usb out to a dac? And can it run roon? Not too familiar with these units but I’ve heard good things...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
I don’t think there is any way to get digital audio out except for HDMI or via the pins themselves. There are ways to run Roon, yes2 Channel in my home attic/bar/man cave
I've had a PI II running usb to an audio-gd DAC for a while now.
Works fine. The PI should work just fine like that, but you'll have to pull the
the other DAC off. I run Runeaudio on mine.
