Rectifier tube, which Mullard GZ34?
Joey_V
Which Mullard GZ34 is the “good” one? I checked eBay and I found the price to range from $30 to $200 but I can’t tell which one is the good Mullard and I don’t like being fleeced by those crooks
I figured there were some tube gurus here that can shed light
Thanks!
Thanks!
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
@heiney9
only thing I have is the made in Great Britain would be a tell tail sign, even that i'm unsure. -
The good one, as above, should be any actual British Mullard. These can come branded otherwise, such as the EICO branded Mullard in my (ahem) EICO ST-40.
ST40frontsanstop by Mark Hardy, on Flickr
^ As found on the scrap-metal pile of the Harvard (MA) town dump some years back. All tubes good and in working order. Why some schmuck left it for scrap metal (not even on the "Yankee Swap" pile) is a mystery for the ages.
I use a Telefunken labeled (Mullard Made) GZ34 in my Cary Audio PH302 phono stage and to me it sounds the best. Probably because Telefunken had Mullard select these tubes for them (just a guess)...
The next best Mulards in my opinion are the ones with the f31 date code (made from 1958-1962) , the f32 are later models (which are also very good by the way).
https://www.ebay.com/itm/Mullard-GZ34-5AR4-1959-Fat-Base-f31-Tests-Strong/282876342454?epid=166829875&hash=item41dcbe70b6:g:qbsAAOSwxdtaoW5u
The Creme of the Crop I hear are the Metal Based Mullards....but these are generally over $300+++
Brent Jesse can explain more about them...
http://www.audiotubes.com/audtube.htm
I can let you try some out if you want so you can decide what works best for you...
But I think you cant go wrong with the f31 or f32 date coded Mullards...
Is this for the SLP-05?
Juan -
IMO Holland made (Phillips) with double D getters are the best GZ34/5AR4. Either metal base (uber pricey) or Black base with metal base innards. My Holland made Black base with metal base innards were branded Mullard. GB manufactured Mullard are fine too.
IIRC Brock (jokingly AKA the tube raider) got a couple of them from me when I sold the 5AR4 gear.
Pictures and descriptions...
http://www.tube-classics.de/TC/Tubes/Valvo GZ34/GZ34.htmSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »IMO Holland made (Phillips) with double D getters are the best GZ34/5AR4. Either metal base (uber pricey) or Black base with metal base innards. My Holland made Black base with metal base innards were branded Mullard. GB manufactured Mullard are fine too.
I still have those in my stash for a rainy day .
Earlier the better. I'll look at which ones I have. I have 3 (2) from 1971 and (1) from 1961 (fat base f31 code), IIRC. They are a bit different construction. The 1971's are RCA label but "B" codes for Blackburn England (f32 code).
There are up to 7 variations of the Great Britain GZ34. If you're not going to spend the coin for the metal base, The earlier fat base GB ones are excellent and last forever (literally) there is no current GZ34 that even comes close to the tone or longevity of the Great Britain or Holland made tubes.
Fat base f31 series is a great one produced from 58-62 and like the name the base is slightly fatter than the later series. Make sure it will fit in your case opening.
f32 series were from about 63-75.
So to recap for Mullard look for the fat base and build code f31 in the first line. Or the later series with the standard base build code f32, but the earlier the better, IMO.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
TubeWorld used to have photo's of the various GB GZ34 side by side showing the visuals. They don't anymore.
The edge of the plates are either smooth, have 3 notches, 5 notches or 7 notches or are smooth and copper looking. IIRC, (going strictly on memory) smooth, smooth copper, 3 notches, 5 notches, 7 notches are the order to get them in from earlier to later.
Can't comment too much on the sound differences because the amp I used them in was a small 10wpc integrated in my office rig. It seemed to me the earlier fat base had a bit deeper tone. Honestly, you can't go wrong with any of them. They sound great and last forever and ever if not abused.
There are reports of lots of Fender guitar amps and Dynaco amps from the 60's still running the original GZ34 rectifier.Post edited by heiney9 on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Here's a photo (for reference) to show the date code and it is later because it has 7 notches on the plate edge and the one on the left has the smooth copper edge. Unfortunately this seller is out of stock currently.
Also most if not all true GB GZ34's will have a hole in the guide pin. Only exception being the very early ones, IIRC.
Juan
No one has really been able to 100% confirm Telefunken made their own GZ34. Most are Great Britain made which TFK then labeled. If TFK made a GZ34 it's a very rare beast. If you are buying European GZ34 it's either made by Great Britain or Holland. America made the 5AR4 and only a few companies made those for everyone as well.
Labels don't mean a lot when determining a tubes origin. It's all about the codes and recognizing construction cues.
I agree the f31 or f32 Great Britain made tubes are excellent choices
Of the few tube sellers I frequent. Brent Jesse is excellent, but pricey.
I've never bought from this guy, but I've heard good things about him. He has a couple in stock.
http://tctubes.com/5AR4-GZ34-tubes.aspx"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
How about a Philip's Miniwatt "Brown base" from Holland 1960 ?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I had a great experience with Brent Jesse, highly recommend talking to him!2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Sure, if it has the correct coding to be from Holland. Both the GB and Holland made ones are great."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
I prefer the 58 (f31) sittard Holland in my 05 over the f32 Mullard. Seemed to have better balance, soundstage, and an overall smoother sound. Both Tubes are labeled amperex with the bugle boy tooting away. The Holland tube was NOS the Mullard is used, and tests as new.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
For you, Joey! Don't skimp and go straight to metal base Amperex / Mullard / Siemens /Adzam /Philips 5AR4 (GZ34) only. Should stamped TV2 57E on the base.
Post edited by megasat16 onTrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Good luck finding one. And if you can they are in the 3-400 range. Which in my opinion isn’t worth the money.2 channel:
Theater:
I get my tubes from Andy at Vintage Tube Service. I use a Mullard Big Base GZ34 1950's version in my Allnic Phono stage. A big jump in sound, by adding a rectifier tube! That's why I keep coming back to this insane hobby!Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
