Polk LSI7 fried voice coil
I recently purchased Polk LSI7 speakers used and set them up with a Denon x4000. My receiver went into protection mode and one of the polks smelled pretty bad. I'm pretty sure the voice coil fried from my reading as the woofer doesn't move very well and I feel it rubbing/scratching when I lightly press on it. The crossover looks fine but I'm in no means an expert. I just don't see any cracks or burns. I have a few questions:
- Can I still get parts or can it be repaired?
- What did I do wrong? I noticed the center channel wires were loose but I can't remember how the broken speaker was.
- Can monoprice speaker wires cause issues? They are connected bare wire.
- Is 85DB too loud? All level adjustments were in the negatives and the broken speaker was at 0DB as it's furthest from the seating position.
- Is it just the 4ohm speakers should be on a separate amp?
I have the 2 Polk LSI7's, and 3 8ohm Angstrom speakers for center and surrounds. And a JL Audio E110.
  • pitdogg2pitdogg2 Posts: 10,555
    Clipping from the receiver more than likely
  • bcharlesxplbcharlesxpl Posts: 10
    Should clipping be something I have to listen for or is it very noticeable? I heard of that but didn't think I was hearing clipping
    distortion, compressed sound stage. you said it was at 85db, how many speakers were running at the same time?
  • txcoastal1txcoastal1 Posts: 9,870
    What was your xover setting to the sub?
    Were the speakers set to small?
    I had 5 speakers going at 85db, it was near the end of The Dark Night Rises and sounding pretty good then the receiver went into protection mode. xover is at 60 and I set them to large. Maybe that was another mistake.
    when you run more than two speakers the power to the rest of the speakers decreases dramatically and clipping can occur very fast. yes those should be set to small and the sub should be doing the heavy work.
    if you had them set to large the xover at 60 wasn't doing anything
    Large is full range
    Speakers set to small, xover at 80
    So when I fix the speaker. Should I be ok with xover at 80 and set them to small. Or should I also think about adding another amp. The x4000 has pre-outs
    Should not need an amp
    Should I stay away from 85db? Is that close to the max? Thanks for all the help by the way. It's very much appreciated :). I usually have a cheap HTIB setup.
  • ZLTFULZLTFUL Posts: 4,572
    The 85db volume level isn't too incredibly accurate and with the speakers set to large, they were running full range. That definitely caused a clipped signal from the receiver.
    My advice follows the above. Once you have repaired the damaged speaker, run them as small and set the crossover to 80hz.
    Bear in mind that the lower the signal and with a 4 ohm load, the chances for a clipped signal increase dramatically.
    Ah I wasn't sure if it's a standard or not. Was hoping it was lol. Ok, I'll make those changes. Appreciate the help. I do love these speakers so maybe I'll put them in a 2.1 system for music one day and get 8 ohm speakers for a home theater. This is a dangerously addicting hobby
  • K_MK_M Posts: 1,026
    edited March 8
    You may have simply been playing it too loud.
    A 5.25" woofer running full range with a very loud movie soundtrack....
    Clipping tends to burn up tweeters.
    Did it go out of protection mode after shutting the receiver off and back on?
    Does that channel of the receiver still work?
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-
    Epos-
    Infinity-
    Advent-
    Yes, came back on fine and all channels still work so I got lucky there
    I mean once i disconnected the fried speaker
Howdy, Stranger!
