Sources for granite pieces?
I'd like to get a couple granite pieces cut (apprx 12" x 16" x 1" thick) to set my speakers on to get a little more height for the tweeters.
Know any sources for smaller pieces?
  • rooftop59
    rooftop59 Posts: 7,981
    when we remodeled our kitchen about 4 years ago, I just asked to have two I think 10x12 pieces cut. Since I had just dropped about $5500, they threw them in for free. All granite places have tons of scrap, they probably won't give it to you for free if your not buying a large piece but it shouldn't be too pricey either.
    If you were closer I would let you borrow my pieces to try out, I'm not using them...I would ship them to you but I think it'd be cost prohibitive and it looks like you want slightly bigger pieces anyway...
    Game Room 5.1.4:
    Bedroom 2.1
  • Legender
    Legender Posts: 478
    Might check stacking up some tiles from HD/Lowes... just to try it out. 3/4 might give you the 1 inch you're looking for.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • marvda1
    marvda1 Posts: 4,873
    kitchen counter top installers, but for sound reasons i would go wood.
    check bed,bath and beyond for their large acacia wood butcher blocks. you can use your 20% off coupons.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • steveinaz
    steveinaz Posts: 19,522
    Appreciate the offer, but I need 16" L.
  • sgmsmg
    sgmsmg Posts: 542
    Do you remember what the dimensions of the acacia cutting boards were? I just searched and I am not sure which one?
    Pre:Bryston BP173
    Amp:Bryston 14B3
    Speakers: Golden Ear Triton Reference
    Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90/JBL SDP-55
    Amps: Parasound A31, A51x2
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • steveinaz
    Thanks Skip
  • rooftop59
    Game Room 5.1.4:
    Bedroom 2.1
  • tratliff
    tratliff Posts: 1,663
    I went with a local kitchen/bath countertop fabricator. They cut them to my demisions but I was also having a peice cut for the top of my audio stand. Think I paid $500 in total. You should be able to see them in the picture attached but they match the carpet pretty well.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • delkal
    delkal Posts: 764
    How well does a flat wood or marble board work on carpet? Do you have problems with vibration? I wouldn't think a large surface area on a squishy surface would be good.
    Did anyone think of putting spikes on them?
    pitdogg2 Posts: 24,579
    I'd spike them! For sure!
  • rooftop59
    I don’t think Steve has carpet...he likes the rubber footers but wants them higher it sounds like...
    Game Room 5.1.4:
    Bedroom 2.1
  • steveinaz
    My speaks are on tile and a concrete subfloor. Vibration isn't an issue.
    tonyb Posts: 32,906
    tratliff wrote: »
    Dang bro, that looks pretty effin' awesome.
  • steveinaz
    Yeah, it looks real nice. I like the matching rack top.
  • afterburnt
    afterburnt Posts: 7,892
    DSkip wrote: »
    Here is a picture of the acacia boards. Let's just say I refer a lot of business to bed bath and beyond nowadays.
    Are the big ones spiked?
  • verb
    verb Posts: 10,176
    Any granite shop will sell you remnants for cheap. They'll even cut em to size and polish/shape the edges. Mostly they just want to get them out of their shop, as they want to sell entire countertops.
  • steveinaz
    Found a couple of 12" x 18" x 1" Acacia boards and affixed some small hard rubber feet on the bottoms. Cool. Now the T2's are at 42 1/2"---perfect.
