Do USB cables make a difference?
gudnoyez
gudnoyez Posts: 8,056
Ok don't want to start a big controversy but do they? A simple yes or no will do. I'm sure some of you have spent more than what these Wireworld Starlight 7's cost, but I'm going to find out if these are any better than the Audioquest Forest ones I own along with some other ones, only have been listening a couple hours with the Starlights and I'm noticing a difference, I'm hoping it's not the placebo effect, but so far the 1's and 0's are sounding better coming out of these red cables, after a couple of hours of tunes and beers.
  • BlueFox
    BlueFox Posts: 15,251
    No experience here, but too many others whose opinion I generally trust feel they do.
  • Joey_V
    Joey_V Posts: 8,505
    People around me say yes
    I’ve never tried
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    F1nut Posts: 49,708
    What's a USB cable?
    pitdogg2 Posts: 24,477
    The blue and green ones sound better.
    Red not so good.....
    Haha
    edited March 2018
    DSkip wrote: »
    It's not about the data - its about the noise that travels through the system. A digital cable is still an analog cable. How the DATA is transmitted doesn't matter as much as how the NOISE is transmitted.
    I thought the Platinum Starlight was such a great investment (one of the best my system has seen) that I now own three of them.
    I bought these cause you did not sell me yours Skip. :#
    quote="Joey_V;c-2389479"]People around me say yes
    I’ve never tried[/quote]
    Ha I bet when you do try Joey they will cost 3 times what these Starlights set me back want to hear a report when you do.
    tonyb Posts: 32,902
    I would imagine they do.....if other digital and analog cables do.
    Toolfan66 Posts: 16,834
    I have yet to try a USB cable that made me take a step back and wow me...
  • GlennDog
    GlennDog Posts: 3,084
    edited March 2018
    DSkip wrote: »
    I'll let ya know later this week . . . I'm expecting a WW cable . . . very soon
    Tho, it will need running-in
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • FestYboy
    FestYboy Posts: 3,861
    Not to flame, but wouldn't an optical be better? Hard to transmit EMI noise through photons...
  • Joey_V
    Joey_V Posts: 8,505
    FestYboy wrote: »
    I think part of it is the optical has no ground.
  • halen
    halen Posts: 675
    I have found zero difference in USB cables.
  • vcwatkins
    vcwatkins Posts: 1,993
    I have five or six usb devices so have tried several cables. Upgrading from basic definitely improved my den and study sound, beginning with the Wireworld UV, WW Starlight Red, AQ Carbon, and WW Starlight Silver. The first two added an organic and more 3-dimensional quality. The Carbon is well thought of, but just didn't do anything special for me. Beyond those above, I have found (varying degrees of) improvement in detail retrieval and frequency response and sometimes a
    slight frequency emphasis.
    These vary quite a bit in price, but ones I like most are: Lush, WW Starlight Platinum 7, Curious Cable, and DH Labs Mirage.
    I would encourage folks to pick one within budget and give it a try to see firsthand.
    Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • Mikey081057
    What would you rather have a $2200 dac and a $100 cable or a $1600 dac and a $700 cable?
  • halen
    halen Posts: 675
    I don’t know how pricey usb cables are but. If it were a $30 cable vs same price dac, I would take the cable.
    If it were a $2000 or $20,000 dac v cable. I would take the DAC. I have heard DAC’s that make a world of difference. USB cables? None to date. Not hating as I do know cables in other areas make a difference.
    Cheers
  • vcwatkins
    My favorite of the ones I mentioned is $250 new. Very much worth that to me personally. Dunno re the zero-sum hypothetical. I always seem able to rationalize whenever necessary, hehe. So probably the $2000 dac and then HAVE to get a good cable. To me, "It all matters" includes usb cables.
    Well running this Starlight since yesterday zero dropouts, or digital clicks or pops, using a run of the mill USB cable or a amazon one I would experience those issues on occasion, so I guess spending a little bit of money on a good cable is worth it. I was considering a Audioquest Jitterbug, or a IFI Silencer, no longer needed running this Starlight 7.
  • ALL212
    ALL212 Posts: 1,553
    edited March 2018
    Joey_V wrote: »
    FestYboy wrote: »
    USB doesn't offer an optical flavor that I know of. The digital output of something would but this isn't it.
    IMO... a digital output in optical, in theory, should be better (ground has no bearing on that). But you've now introduced two transceivers, one on each end. So electrical impulse to light - across the fiber - back to electrical impulse. If the transceivers putting light on the fiber and then taking it back to electrical suck or are bad or are dirty or the fiber has fractured or... It's just one more thing in the signal path and you have no control of that at all. If you're going to run that signal 1000 feet strapped to a 440vac 3 phase I'm all in. I've been through optical and prefer, by a long shot, the copper lines.
    Soapbox put back under the desk.
    Aaron
    Enabler Extraordinaire
  • Joey_V
    Joey_V Posts: 8,505
    edited March 2018
    Atkinson and McGowan discussed noise as a principal issue with optical and they linked it to lack of ground, beyond that i have no personal experimentation that would lead me to believe its inferiority or superiority.
  • halen
    halen Posts: 675
    Who cares about theory or on paper. Try it out and experience it. Theory or on paper should not command you like a master. Or does it?
    Not me.
  • BlueFox
    Well, my parents used to ask me if I was going to stick my hand in the fire to see if it is hot. FYI, it is. :)
  • halen
    halen Posts: 675
    Haha. I will be doing lots of traveling soon. Bud, you happen to be one of my cities. Would love to have some drinks! And touch them Magicos. Haha
    Cheers.
  • BlueFox
    Sure. PM me when you have a date. Didn’t you grab my free LSi15s, LSiC, and Oppo in 2016?
  • Joey_V
    Joey_V Posts: 8,505
    halen wrote: »
    Not me.
    Agreed.
    I have learned that theory in this hobby doesnt exactly translate to results.
    As I said, I have not tried to compare with reasonable sweat equity various digital cables against each other to make a personal assessment. I can only repeat what others have said with regards to certain digital interconnects, etc.
  • halen
    halen Posts: 675
    BlueFox wrote: »
    Yep. Paid almost $1000 to have them shipped to me. And then I gave them all away.. All of them.
    It was a awesome karma you did. I passed it all along on my dime after.
  • halen
    halen Posts: 675
    Joey_V wrote: »
    halen wrote: »
    Not me.
    Agreed.
    My response was not towards you but my experience with USB topic, in general. Much respect to you from me.
    Cheers
  • BlueFox
    halen wrote: »
    BlueFox wrote: »
    Great. I hope the new owner enjoys them. I know I did.
