PSW111 Repair!!!!
oldegwitz
Greetings,
I have a PSW111 subwoofer which is damaged. A few months ago I went to a Technician here in Venezuela to try to fix a buzzing noise it has. As it turns out he gave me back the Subwoofer with missing components on the internal PCBs and I want to send it to a Certified Repair Center in USA to try to save it. Any suggestions will be appreciated.
Best Regards
Best Regards
@KennethSwauger should be able to help.
How old is the sub, did you buy it from an authorized dealer and do you have the receipt?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Might not matter since it was damaged further by an unauthorized "repair" facility.
Hi guys, I bought it on Crutchfield, yes I have the receipt and It is out of warranty, that's why I tried first here to save it before sending it back to USA, which is more expensive.
I don't know what Polk charges directly but you can buy a new Amp board for about $100 to replace yours. The Speaker Exchange in Tampa, FL would likely ship to Latin America.
