Centre channel for RTi150
Hello,
I have a pair of RTi150 towers that I would like to use a fronts in Home Theatre set up. I would like to get the biggest Centre channel that I can to work sonicly tweeter wise and woofer wise with these towers.
So far I have found the CSi40, CS400i or the CSiA6. not sure which would work the best , or if there is a different bigger one??
  • rooftop59
    rooftop59 Posts: 7,994
    Csi40 is the exact match with the same tweeter. I think a cs400i would also probably be pretty close. I wouldn’t go for the csia6.
    The biggest close match would be the cs1000i (same tweeters as cs400i) with built in powered subs. But they are difficult to find and often expensive, and the amps are known to fail. I would stick with the csi40 if you can find one and just get a nice sub.
    Game Room 5.1.4:
    Bedroom 2.1
  • Airplay355
    Airplay355 Posts: 4,298
    Csi40 would be perfect.
