Power Strip with IEC Inlet?
DaveHoDaveHo Posts: 1,926
Wall warts, I've got a bunch of them. Phono-pre, speed box, Ethernet switch, powered USB HDD, Chromecast. Given their size, they cannot be plugged into my power conditioner without the use of short(1 ft) extension cords. What I am wanting is a quality power strip to plug these into.
My wants are:
1) Detachable inlet cord. It will be piggy backed onto the conditioner. No need for a 10ft cord or surge protection.
2) Outlet spacing to accommodate the warts.
3) A couple USB ports would be nice.
I don't think an audiophile geared piece is warranted for wall warts. Cost, less than $50 not including the cord.
So far all I've come up with is this, and it really doesn't fit my needs:
https://amazon.com/gp/product/B0094BC32Y/ref=ox_sc_sfl_title_5?ie=UTF8&psc=1&smid=A1OE7CV49TO1OJ
I'm not wanting a piece of pro gear that's designed to be rack mounted. There's got to be something else out there.
  • DaveHoDaveHo Posts: 1,926
    Thanks! However, only 2 receptacles. Really need a minimum of 4 since the chromecast is the only one that's USB powered.
  • ClipdatClipdat Posts: 4,503
    Yeah, this is a tricky product you're looking for. Found this but it's above your budget:
    http://www.fullcompass.com/prod/181526-Lowell-ACS-1505-SW
    DaveHo wrote: »
    Got Dayens?
  • EndersShadowEndersShadow Posts: 15,860
    edited February 15
    DaveHo wrote: »
    Signal Cable... just ask for a custom length (re 1 foot).
    It looks like that would still be a clearance problem with large wall worts.
    DaveHo wrote: »
    Got Dayens?
    Thanks for the suggestions. Thinking about DIY'ing it.
    I think I'm going to go with the Furman PlugLock.
    furmanpower.com/product/12a-power-distribution-strip-no-surge-protection-5-spaced-outlets-wbrackets-5ft-cord-PLUGLOCK
    No IEC inlet but the cord is sorta short @ 5ft, plus it's 14awg, so plenty thick for my intended purpose. There might be room to retrofit an IEC or I can likely shorten the captured cord without much trouble.
    Now to wait and see if the eBay seller will accept my offer.
  • afterburntafterburnt Posts: 4,425
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
    Clipdat wrote: »
    DaveHo wrote: »
    You can make beer on the wall?
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • SCompRacerSCompRacer Posts: 6,874
    edited February 18
    Due to HVAC, I couldn't put an outlet where my amp and subs are. So I split a duplex outlet for two 20A amp circuits.
    I bought this four outlet aluminum box on ebay and stuffed it with goodies from Douglas Connection. 10 gauge wire from wall to box, box came with IEC cutout in end for extension. They had longer and larger square sizes at the time.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
    Thanks for the suggestions. I have the Furman on the way. It will work well for the wall wart application.
Howdy, Stranger!
