Amplifier freq response specs question...
Okay, I need a little primer here. I've been looking at specs for various receivers/amps and it occurred to me that I don't understand something that I think should be quite fundamental.
For example, here are some specs for an old Kenwood stereo receiver (make and model don't really matter for this discussion, I think):
Power output: 80 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.02%
So, let's say I'm running this amp to watch a movie with significant sound effects dipping below 20 Hz (whether or not I have speakers/subwoofer that can reproduce it or not). Here's my question, will this amp be able to produce those sub 20 Hz signals to send to the drivers? If so, which is my guess, is that the distortion levels increase? I have seen older vintage receivers that claim 5-20,000 Hz freq response.
Thanks in advance for any insight.
  • FestYboyFestYboy Posts: 2,525
    I have yet to see an amp that can't dip into the single digits. The specs you see are a little suspect without a +/- dB spec, but still, there's no reason any amp can't get lower than 20, though they might not have the amperage capacity to get a speaker to do any real work down that low. Also, as power requirements go up, so does THD. So in your example, at 80w, the THD is 0.02%, but at say, 110w it might be at 0.15%, and snowball from there. The Kenwood may be good for 200w peaks @ 1%, but that doesn't look good for HiFi.
  • daddyjtdaddyjt Posts: 619
    Those specs are fine, and that amp will easily produce sound below 20hz, and I would suspect at reasonable distortion levels.
    Specs are just a marketing game. For example, an amp may have ALL of the following real world performance numbers:
    50wpc, 5hz-25khz, .005% thd
    100wpc, 20hz-20khz, .05% thd
    200wpc, 20hz-20khz, .1% thd
    450wpc, 1khz, 1% thd
    Now the question the marketing department has to decide is, “who are we marketing this amp to”?
    An audiophile will be most interested in the first set of specs, a home theater buff the second or third, and bubba will like the fourth.
    It’s easy to get caught up in the numbers in this hobby - don’t forget to enjoy the sound :smile:
    Too much stuff to keep track of.
    Currently enjoying: Legacy Focus 20/20, McCormack DNA 225, Bill D C1, Oppo 105
  • madmattmadmatt Posts: 16
    Thanks for the replys. I don't have that Kenwood nor plan on getting it. This has been more of a theoretical muse. From the pure electrical engineering perspective of your average audiophile amp (however you define that), what is the limiting factor to providing the "oomph" to push a driver in that deep freq range (that FestYboy referred to)? What does a high power amp with lots of overhead have that a low end "wimpy" amp doesn't?
    Which leads to ask , if shopping for an amp and maybe more specifically a sub-amp, what numbers ARE important?
    Perhaps I'm overthinking this, which is entirely possible. My father is an engineer, so his engineer brain rubbed off on me. We like to understand how things work.
  • afterburntafterburnt Posts: 4,425
    Better to be rubbed off than rubbed out is what always say.
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
    Capacitance and peak short term current capacity <100ms with a good damping factor is what you want for any good amp, but especially for one dedicated to a sub. Also it's ideal that the amp is stable to 4 ohms or LOWER. You'll note that most big boy amps are good for at least 35A and 4ohm stable.
    Well, me and my Carver M1.5T should be okay on that front.
    madmatt wrote: »
    ...what is the limiting factor to providing the "oomph" to push a driver in that deep freq range (that FestYboy referred to)? What does a high power amp with lots of overhead have that a low end "wimpy" amp doesn't?....
    That's a very complicated question, and involves more than just your amp selection. What your amp will do (or NOT do) is as much a factor of the speaker its driving, as it is of the amp itself.
    Your 1.5t is a great voltage source amp (as are most Carver amps). It will perform admirably into 8 or 4 ohm loads, but will protest going below 4ohms consistently. It also has a very spartan (read "not warm") sound signature. Not an ideal pairing for Klipsch:-)
    Current source amps tend to have LARGE transformers, and A LOT of filter capacitance (>40,000uf). 2 ohm stability (and by that I mean ALL DAY stability) is a prerequisite to any amplifier considering itself a current source.
  • pitdogg2pitdogg2 Posts: 10,227
    edited February 13
    some lite reading. Marketing will determine how they rate many things in audio. back in the 70's they played fast and loose in the ratings.
    http://soundandsong.com/Issue004/004_PowerAmpRatings.html
    https://en.wikipedia.org/wiki/Audio_power
  • pkquatpkquat Posts: 576
    madmatt wrote: »
    daddyjt wrote: »
    The speakers impedance curve also plays a part. The impedance of an "8 ohm" speaker can vary greatly depending on the frequency. Some speakers don't vary much, and others can dip heavily into the 2 ohm and/or 16 ohm range, or extend beyond 32 ohm.
    For sub woofer amps, thoughts vary. Many are going to a Class-D SS amp. They provide lots of economical power. Their main issue is inconsistencies as it switches from positive to negative. This is much less noticeable at lower frequencies, and not considered that big of an issue for sub woofers (generally speaking).
Howdy, Stranger!
