Help Me Spend My $$$
I am always in this debate...crossovers on my 2Bs or REAL amplification?! I have always desired a Marantz Model 250 but do need these crossovers refreshed. I can only do one this year, I can do the other the next.
GAHHH
Living room
Mains: Paradigm 90P
Lows: Velodyne CHT12, Pioneer SW-8Mk2
Power: Marantz SR7000
Tv: Samsung UHD 55' Curved 4k
2 Channel Den
Mains: SDA2B Upgraded XOs and Binding Posts
Pre: Denon PRA-1200
Power: Adcom GFA-545
TT: Pioneer PL510
Tv: Samsung UHD 55' 4K
Noggin Rockin'
Phillips L2
Grado SE80
Harman Kardon CL
Little dot 1+/GE JAN 5654w
Closet of Dreams:
Harman Kardon AVR130
Yamaha HTR5590
Polk RTA11TL
Polk TSI200s
New Large Advents 25th Anniversary Edition
Bravo V2/RCA Clear top Conn branded 12AU7
Yamaha AV-34
  • MrBuhlMrBuhl Posts: 2,308
    Tough one, IMO, a Marantz 250 is likely to need some refreshing too at this point won't it? If that's the case, I would do the crossovers first.
    If you're talking about getting something shiny and relatively new and going separates, I would do the amp.
    There, I managed to provide no solution and give two answers, my work is done.
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
  • tonybtonyb Posts: 29,769
    crossovers...
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1430 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • codycatalistcodycatalist Posts: 1,632
    MrBuhl wrote: »
    I saw one on Ebay for $599 that was just serviced. I didn't go into the details of what was refreshed but will look again.
    @tonyb I know this is probably what I should do but I think of it like this. What if I have to put my 2Bs away or end up with a different pair of speakers until I have the REAL space for them. The money will not be wasted but won't be enjoyed, I know the crossovers will make the biggest difference in sound quality especially with my almost 20 year old caps.
    Would it be worth it to go cheaper on the crossovers (not Sonic Caps) and get maybe a Parasound HCA1500? I have a nice Denon Preamp in my closet that needs some deoxit but should be good besides that.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
  • ConradiclesConradicles Posts: 5,748
    I would go less expensive crossovers and a new amp. Both problems solved. I have used Jantzen and Dayton caps with excellent results.
  • EmlynEmlyn Posts: 2,132
    Personally, I would find a good condition Parasound HCA-1500 and wait on the crossovers or just make minor updates to them. Have the tweeters on the 2Bs been updated already? If not, that's where I would start.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • smglbrthsmglbrth Posts: 1,075
    If there is nothing spooky going on with your 2B's then definitely an amp. Tweeters are a must if you haven't done that already, so, that would be first, then the amp. My .02....
    Emlyn wrote: »
    I did get some RD0 194s but both batches were bad and cause a resonance on certain piano frequencies. I put the SL2000s back in for now, kinda put off of the Rd0s due to bad experience. I don't want to drop another $90 for buzzing tweets.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    edited February 6
    If you hurry - there are still some Clarity caps out there for close out in the PX and ESA line, but the quantities are dwindling fast, my 2Btl's have Solen in the low-pass and ESA's up high and sound great IMO. Come to think of it, I might have some 12uf Clarity PX leftover at home I would give you. I'll check weekend after next and let you know if you're interested.
    Polk SDA1c modded
    Yamaha YP-D6
    I also plan on spiking the 2Bs as I lost a lot of bass reinforcement when going from a carpeted room to a wood floored room. I hope that will restore what I am missing.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    MrBuhl wrote: »
    Bonus won't be in until later this month but I plan to go through Dave (DHS) to upgrade the crossovers as my soldering skills are how do I put it...non existent? Yeah that sounds about right.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    TNTsTunes wrote: »
    Emlyn wrote: »
    Skip the RDO194's and rebuild the crossovers so they use RDO198's.
    SDA 2BTL's for the win.
    I know TLing them is advised, I will discuss with Dave when the time comes but I am seriously considering it.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
  • DSkipDSkip Posts: 14,892
    Speakers first. Stock sda are not pleasant in my experience. Upgraded they are definite contenders.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • Viking64Viking64 Posts: 3,294
    Crossovers with built-in amplification or amplifier with built-in crossovers.
    Either way = problem solved.
  • Gerres26Gerres26 Posts: 347
    MrBuhl wrote: »
    I agree to go with the crossovers first. I was able to snag all of my clarity esa caps at like half off a little while back due to close out sales. Definitely made buying nicer caps a little easier on the wallet.
  • gmcmangmcman Posts: 1,213
    Crossovers.
    That way once you start changing components further up the chain, you will be able to hear what the end result will be.
  • dpowelldpowell Posts: 2,772
    If those are your long-term speakers then do the XOs. Those old caps are worn out. You'll be surprised how much better they'll sound overall including improved bass response with new caps.
    polkaudio Fully Modded SDA SRS 2.3TL's + Dreadnaught, LSiM706c, 4 X TC265i Rears, SVS PB13 Ultra x 2
    Pass Labs X1, Pioneer Elite SC-67, Sunfire Signature Cinema Grande 400, Oppo BDP-83SE, Sony SCD-C333ES
    dpowell wrote: »
    Oh I don't doubt it, I think the loss of bass response is placement (still 6 inches off the backwall but I have them 8 feet apart with a entertainment center between them) and my new room which is laminate wood flooring instead of carpet. I am hoping that spikes will help with this, if not ill just deal with it.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
  • Maybe spend some of your dough on a powered sub?
    Spikes improve pretty much all speakers. Fact!
    Slapaho wrote: »
    I currently have a Velodyne CHT12 in the mix so that's covered.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    Update - Packed my crossovers up and getting them shipped out to @westmassguy today for some upgrades. Pretty excited to take this step and see what comes of it.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    Cool man, they're in good hands.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1430 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    I plan on spiking these at the same time. Anything in particular I need to know about removing the riser and drilling the holes?
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
  • audioluvraudioluvr Posts: 447
    edited February 14
    You could remove the base, use it for a template, cut you an insert and install it to make it flush at the bottom. Just a thought
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    B&K Reference 50 Pre
    B&K M200 Sonata Monoblocks
    Cambridge Audio DVD 99
    Sangean HD FM Tuner
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    audioluvr wrote: »
    I don't have experience with wood work or removing them ao I am more curious of it is held on my glue and I slowly and carefully pry it off with even distribution etc etc.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
    Flip them upside down and post a picture. So we can see what you're dealing with
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    Waiting for the crossovers to be sent back, I started thinking about amplification more. I know B&K is highly regarded around here, I saw a B&K ST2140 for $200 recently, I read 140 watts into 8 ohms and I am sure it has plenty of current. Anyone have experience with this model or similar?
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Pre: Denon PRA-1200
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    Yamaha AV-34
  • JayMXJayMX Posts: 117
    edited March 4
    I run a ST1430 (it's three channel so I have one spare) on my SDA SRS 2’s and I really love the sound. Very transparent. I always wish for a little more umph, but what good is a rabbit hole if it isn’t deep...? I think the 2140 has very similar guts but some newer features like remote trigger balanced inputs and I'm not sure if it has gain pots but if it does that would be nice, mine doesn’t. Well built, simple design. Supposed to be 185wpc into 4ohms. I paid $150, so if you can get it for $200 I’d jump on it.
    Upstairs 5.1.2:
    Marantz NR1607, L/R - Modified Monitor 7C (194’s, Dynamat, Sonicaps, Mills, H-nuts), Center - Yamaha NS-C310, Surrounds/height/Atmos - (4x) Proficient in-ceiling, Sub - RBH TS10AN, Marantz DV7600
    Downstairs 7.2.4:
    Marantz SR6011, L/R B&W DM604, Center - RBH 700-CX, Surrounds - Monitor 5a (Peerless), Surround Back - Monitor 4a (Peerless), Height/Atmos - (4x) Polk RC60i, Sub#1 - JBL 12” frankespeaker, Sub#2 - Klipsch RSW12, Samsung bluray
    2CH: Kenwood KA-8150, Adcom GFA 555, L/R - SDA SRS 2, RTA12C (194's)
    Office:
    Cambridge Soundworks Amp
    Monitor 4b (Peerless)
    Spares:
    Monitor 10b (Peerless), Monitor 7b (Peerless), Monitor 5b (SL2000), Monitor 5b (SL1000)
    Repair pile: SDA2, SDA1b
    ...and more to come, it’s a sickness.
    I recently reworked some SDA 2's that had water damage to one of the bases. I removed the base pretty easily. They had been glued on and there was one ~2” finishing nail driven through the base, centered on each side. I used my Dremel to remove a little wood around the head of each nail then used vice grips to get onto the nail head and they pulled out with some effort. I was then able to pop the old glue with a sharp (but careful) blow or two from a rubber mallet.
    Upstairs 5.1.2:
    Downstairs 7.2.4:
    Office:
    Spares:
  • GlennDogGlennDog Posts: 1,541
    You are going to be SO HAPPY !!
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Definitive Technology BP-2
    DAC North Star Design Supremo
    Source PSA PWT & Oppo 105
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Pre Cary SLP-98 F1
    Center Salk HT2C
    Wires MIT S3.3
    PSA PC AC-12
Howdy, Stranger!
