Are SW120's and SW121's interchangeable?
I've been in the middle of my 1C upgrade path and as a lot of you folks, looking for spare parts. Lot's of SW121's out there, but the SW120's are not as abundant. My 120's are fine, as I only had to do a minor surround repair. Thanks @f1nut and @westmassguy for your tutelage on that!
I've learned that the SW120's have at least 2 different variants. One with a thicker "cone" and one with a thin cone plus a weight on the Styrofoam piece on the backside.
Borrowed from @Mrbubbles2 post (2011) SW120 circa 1983. Thin cone plus weight:
I also have the same ones with the thinner cone and weight circa 1987:
Can I swap out the 120's with 121's if needed? Obvious question are the sonic differences significant? Newbie slack in affect here :smiley:
Or should I stay on course (wait for 120's) within the rabbit hole or am I veering into a ditch by snagging a set of 121's?
Please advise.
    F1nut Posts: 49,794
    The 120 and 121 have different weights and therefore different specs, so not a good idea to swap one for the other.
  • verb
    verb Posts: 10,176
    Thanks Father. I will stay the course. Patience grasshopper.
    pitdogg2 Posts: 24,556
    I have many spare passive's which do you want sw120 or sw121
  • verb
    verb Posts: 10,176
    SW120! Would like 2 of em!
    verb wrote: »
    Let me check and see
    Looks like i have 3 pair of sw 121
  • FestYboy
    FestYboy Posts: 3,861
    edited February 2018
    You do not even want to know the MW drivers I'm sitting on...
  • verb
    verb Posts: 10,176
    Dang!
    Sw120 has the bolt weight correct? Two of mine are dynamatted so i cannot see number. I'll take some out of my active speakers see if they have the bolt. These i put second skin on so if they have the bolt weight we'll go from there.
    txcoastal1 Posts: 13,132
    FestYboy wrote: »
    Hoarder!
    verb wrote: »
    Dang!
    Don't be jelly...that's all he got out of the divorce :p
    txcoastal1 wrote: »
    FestYboy wrote: »
    Hoarder!
    verb wrote: »
    Dang!
    The truth hurts but Ron hit on the head
  • FestYboy
    txcoastal1 wrote: »
    FestYboy wrote: »
    Hoarder!
    verb wrote: »
    Dang!
    The truth hurts but Ron needs hit on the head
    Fixed
    Nope...
    Careful Ron will give ya a good flexin
  • verb
    verb Posts: 10,176
    Yup mine has the weight. There is a SW120 version w/o the weight too.
    verb wrote: »
    After work tomorrow I'll take apart the SDA1 signatures I'm real sure i put SW 120's in it.
  • FestYboy
    Nope...
    ;):p
  • verb
    verb Posts: 10,176
    Yeah work tomorrow. Ugh. Thanks @pitdogg2 !
    Viking64 Posts: 6,679
    I had a bunch of 120's but when I tested them, there was no continuity, so I threw them out. B)
  • verb
    verb Posts: 10,176
    Thanks @pitdogg2 but those are 121's. :neutral:
    Yes i know just putting it out there for others.
    All of mine are sw121. The pair in my SDA1Signatures are as well.
  • verb
    verb Posts: 10,176
    Thanks for checking!
