SDA Passive Radiator SW-120
On3s&Z3r0s
I'm doing some storage spring cleaning and getting rid of some pieces and parts I don't have any foreseeable use for... found an SW-120 I had as a spare for some SDA 2's. This PR is the 12" kind with the thicker foam disc, used I believe in all the SDA 1's and the first gen SDA 2's (not the 2A's or 2B's). It looks like it's still in great shape with none of the blistering that sometimes happens on these.
If anyone has any use for it, let me know and it's yours for the low, low price of free, plus shipping. If interested, just PM me your zip and I'll look into what it would cost to ship it.
If it works for SDA 1As then I will take it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I'll step in line next if it doesn't work out for @EndersShadow
Wow, more popular than I thought... first PM by timestamp was TNTsTunes, Enders is next... I'll box it up and see what shipping will run.
Did the SW120's come in different variants??? I have PR's labelled SW120 in my 1C's that have the thinner disc (no foam), and a weight in the styrofoam piece. Both PR's are the same, labelled SW120. Anyone have an idea???
Reference post for surround repair that I am pursuing on one of my PR's:
http://forum.polkaudio.com/discussion/180261/pr-surround-repair#latest
BTW great Karma @On3s&Z3r0sBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Yes, the same model came in two versions.Political Correctness'.........defined
President of Club Polk -
Thank you @F1nut I'm assuming they are interchangeable but must be a match set if they are to be replaced. Correct oh guru?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yes i would make sure they match. My take, the foam was heavier so no need for the weight. Some of the first sets with the foam front bubbled badly so i believe they switched to the harder plastic like front and so those would behave the same they added the weight in the rear part. I've used both on my SDA1 signatures. The first set had foam and bubbled a bit. I found no difference in bass response.
Probably best.Political Correctness'.........defined
This is definitely the earlier kind with the foam that sits proud of the surround by maybe 3/16" of an inch or so.
This one's on its way to its new home. Thanks, everyone!
