Cosmetic restorations of equip. Covers
soundfreak1
Have a rt707 cover that needs refinishing (marks and surface rust) anything more involved than simple sanding and crylon????
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
KrylonPolitical Correctness'.........defined
President of Club Polk -
soundfreak1 wrote: »Have a rt707 cover that needs refinishing (marks and surface rust) anything more involved than simple sanding and crylon????
That should work. Depending on how deep the rust is, you may have pit marks or other imperfections in the metal after sanding. To fix, you can use spot putty to fill em.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Take it to a body shop or a powder coater and let them do it any way you want it finished.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Was going to use some 0000 steel wool. Just don't want a "modled" lookMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
