RTA 11t's needing Something
audioluvr
I have a pair of RTA 11t's that I picked up I'm trying to figure out what to do with. They just don't sound very good and I'm wondering if I should upgrade or just get rid of them. Could be my 1C' have me spoiled but the highs are kinda harsh and the bass is very diminished. The cabinet seal is very good so it can't be that. Is there something in the crossovers that is causing this or is this a common problem?
I've never felt there wasn't enough bass from either of my 2 pair of 11Ts, as for the "harsh" highs, you may want to look into TL modding them with the RDO-198s.
What are you driving them with? Have they ever been opened? Possible polarity issue if so. -
+1
Also, they should respond well to upgrading the XO caps to some ClarityCaps or Sonicaps.Stan
Main 2ch:
HT:
Other stuff:
Something is wrong. The 11t/tl are the sweet spot in the MTM RTA line. Great vintage PolksHome Theater/2 Channel:
dhsspeakerservice.com/ -
These are bone stock. Was running them with an NAD T753. While I wait for Dave ^^^ to rebuild my crossovers on the 1C's I'll open them up, do some updates, check polarity and maybe throw in some 194's to see if that helps. As for upgrading the crossovers, that will have to wait for nowGustard X26 Pro DAC
Mine went from night to day with a crossover upgrade to Sonicaps and Mills resistors.
Plus, I am sure the poly switches were shot, which can give a muddy, muted top end.
I used a 0.5 ohm Mills to replace those.
A possible experiment might be to remove the crossovers, and replace the poly switch with a jumper just to see if perhaps they are a problem. Depends on what kind of money you want to sink into the speakers.
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Well I pulled them back out of storage to start updating them. Dynomatted all baskets and swapped out a couple of RDO-194's from my 1C's to see how much that would help. Then I noticed one of the tweeters was not working. Pulled it and stuck a multi- meter on it and sure enough, no signal. Looks like a crossover upgrade is in order...Gustard X26 Pro DAC
And down the rabbit hole you go.
Tick, tock... Deeper I go.
WTH. It's just money... I can always make more!Gustard X26 Pro DAC
Thanks Steve. I'll probably do the whole shebang like you did.Gustard X26 Pro DAC
If you do the whole shebang step up to the TL tweeters and use RDO198's. Cost wise it's probably not much of a difference."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Hmmm. What's different crossover wise?Gustard X26 Pro DAC
11t
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18707.pdf
11tl
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18708.pdf
Not too much, just a few changes in the tweeter circuit.
Cap wise the 11t uses two 12uf caps, 11tl uses a 12uf and 16uf cap.
Resistor wise the 11t use a .5 ohm resistor to replace the poly switch, a 2.7 ohm and 2.0 ohm resistors. The 11tl doesn't use a poly switch and only uses a 1.5 ohm resistor.
To make an 11t into a11tl you would need a .3mH inductor to replace the .4mH inductor the 11t uses."Make a man a fire and he'll be warm for a day. Light
Thanks!Gustard X26 Pro DAC
Well unless I can source 2.7 ohm Mills resistors it looks like a TL mod is in order. Anyone know which is the best / correct inductor to use? Parts Express carries 14, 18 and 20 ga. air core.Gustard X26 Pro DAC
Here you go.
2.7 ohm Vishay Mills resistor.
soniccraft.com/product_info.php/27-ohm-vishay-mills-mra-12-p-4636
For the TL mod inductor choice matters.
I believe this is the correct inductor Jantzen 000-1452 .30mH .55ohm AWG 22
Maybe @westmassguy can verify this.
You'll need to order it from this site below. No one in the states will special order it for you.
https://hificollective.co.uk/catalog/000-1452-0-30mh-jantzen-air-core-wire-coil.html
Since it is special order it takes 18 days for them to get it.
Airmail tracked and signed takes about 7 days. FedEx Int. takes 2-3 but costs almost twice as much.
I've place multiple orders with them and they went great."Make a man a fire and he'll be warm for a day. Light
I'm hoping a 33uF cap will work since I can't find a 34uF one. Thoughts?
Never mind. Just talked to @westmassguy and the 33uF are within tolerancePost edited by audioluvr onGustard X26 Pro DAC
Sonic Craft carries the 34uF, same place for Mills resistors.Political Correctness'.........defined
President of Club Polk -
Thanks F1. My uncanny ability to not see what's right in front of me must be active again. I will keep looking.Gustard X26 Pro DAC
audioluvr,
Don't know where you are, but here's an orphan RTA 11tl, be good for parts if nothing else perhaps.
https://baltimore.craigslist.org/ele/d/polk-audio-rta-11tl-tower/6486339993.htmlSDA SRS 2.3s
Pair of Carver TFM 35s
Carver C-1 Preamp
CAL Icon MkII CD
RTA 12s, need major work -
WOW. Never see deals like that in the West coast.Gustard X26 Pro DAC
At the other end of the scale, closer?
https://www.ebay.com/itm/Polk-Audio-RTA-11TL-Audiophile-Speakers/352257159279?hash=item520429b06f:g:l20AAOSwPK1ZTLD9SDA SRS 2.3s
Carver C-1 Preamp
CAL Icon MkII CD
audioluvr,
You can pass on this... The quality of the pieces from that seller is poor to atrocious. Thinks everything is worth gold untill it sits for months on CL, then there's the issue of contacting him...
If you really want it for parts, sit on it for a while longer, then go in low. -
Closer yes. Still 650 miles South of me. I went ahead and ordered all the components to upgrade the crossovers as is and have RDO-194's coming. Should suit my needs quite well once done. I'll keep you all updated.
Thanks all!
Well I rebuilt the crossovers using the Dayton Audio caps 5% on the low pass and 1% on the high pass. I started by removing the hot glue, cutting off the old caps, resistors and poly switch, labeling the location as I went.
Then I desoldered and removed the old leads. Next I drilled new holes farther apart for the 0.5 ohm resistor that replaces the poly switch and an extra one so the 12 uF cap and 2.0 ohm resistor don't have to share a hole. This made reinstallation way easier and because the new caps were quite a bit larger than the originals, gave me more room. Next I moved the inductor over a little installed all but the one one cap that previously shared a hole with the resistor then stacked the last cap on top.
I pushed all components down tight then bent over all leads and trimmed any excess. This keeps everything tight and in place plus if for some reason fitment isn't right I can still adjust. Finally I soldered and hot glued. Not sure if this is how the professionals do it but it worked well for me.
I did listen to one new and one old to see if I could hear any difference. I noticed that the vocals were far more clear and highs seemed a lot smoother. Still waiting for the new RDO'S but I really like what I am hearing so far.
Thanks again everyone for all the help!Gustard X26 Pro DAC
The 12uf and 34uf are reversedHome Theater/2 Channel:
Chemtronics makes a Flux-Off aerosol (carried at Digikey) that will get rid of the brown flux left after soldering.
One other thing the resistor should never be covered in hot melt glue.....KennethSwauger wrote: »Chemtronics makes a Flux-Off aerosol (carried at Digikey) that will get rid of the brown flux left after soldering.
91% alcohol on a Q-tip works also.
westmassguy wrote: »The 12uf and 34uf are reversed
You funny! They are not polar.Gustard X26 Pro DAC
I believe he's saying that they are in the wrong positions. -
Bad wording on my part. The 34 should be closest to the edge of the circuit board, the 12 closest to the shunt inductor.
