Looking for tweeters for my sda srs speakers
I just purchased a set of these humongous speakers and was told that I should upgrade the tweeters. Any suggestions
Best Answers
  • ken brydson
    ken brydson Posts: 8,648
    Answer ✓
    Call CS, $48ea shipped...
  • pkquat
    pkquat Posts: 742
    Answer ✓
    Tell them you are club polk member for free shipping.
    I would hope CS gets more specific about which model of SRS speakers you have, and what tweeters are in the now. There are two different replacement tweeters depending on the model of tweeter.
    RD0-194 replaces the SL2000 tweeter, often referred to as the fish eye tweeter.
    RD0-198 replaces the SL3000 tweeter, which is dark and shiny, and has a foam ring around it.
    Google for images, include "Polk" with the model number.
    Since you said the speakers are humongous and didn't add any numbers after SRS, I would assume they are early SRS speakers and therefore have the SL2000 tweeters.
    Next up would be refreshing the crossover. Welcome to the forum and the rabbit hole. :p
Answers
  • Mikeg58
    Now I come to find out that the person I purchased them from doesn’t have the interconnect cable for it and need the one with a pin and blade...I called Polk and they don’t carry that anymore... any suggestions
  • michaeljhsda2
    michaeljhsda2 Posts: 2,170
    edited January 2018
    Can you post a pic of the front of the speakers? Need to see what type of tweeters you have. Since it's a pin/blade interconnect socket, they are at least SDA SRS 1.2's (can be upgraded to the TL) and if they have SL3000 tweeters you have SDA SRS 1.2TL's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Forgot to address your question... sometimes you can find a used one for sale on Ebay and in this forum. Some people have removed the pin/blade socket and replaced it with a SpeakOn connector.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Moose68Bash
    Moose68Bash Posts: 3,842
    Time for a Dreadnought! :)
    Welcome to the Forum and the Rabbit Hole!
    What gear are you running with your "humongous" vintage Polks?
    audioluvr Posts: 5,432
    edited January 2018
    You could use a single 12 ga. Speaker wire with banana plugs on each end connected to the IC pins temporarily.
  • michaeljhsda2
    audioluvr wrote: »
    True, I forgot about that idea. Just trim off the petals that surround the pin on the banana plug.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • knish71
    I too am looking to replace my SL2000 tweeters. Who is CS, I’d like to contact them.
    Robert
    pitdogg2 Posts: 24,559
    edited October 2018
    knish71 wrote: »
    Robert
    Polk customer service
    The replacement tweeter is RD-0194
    Call: 1.800.377.POLK (7655) Option 1
  • knish71
    Thank you very much
    Robert
