Amp stands
Considering building a pair of amp stands. What materials would be best for construction? Ie: solid wood, MDF, ect. Also feet, spikes ect. They will be supporting a Krell amp and a parasound 1500a if this makes any difference.any input would be appreciated as this is my first foray into amp Stands.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • DSkipDSkip Posts: 14,854
    The plinth will sound the way it looks and feels. If it's hard, it will have a hard sound to it. Soft will be soft. Giving it a knock will help you get a sense for the tone it might introduce to your system. The resonance of the material will transfer to your gear and music unless you isolate.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • soundfreak1soundfreak1 Posts: 2,823
    I do have some isolator matting for high sensitivity lab equipment that I use for my turntable I guess I've got plenty to use for under the amps if necessary but just curious about materials as to what would be the least offending material to build them out of?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Hdf would be a good choice but it's hard to find in a decent thickness. Mdf is good as well. Composite materials are better because they break up the natural resonances.
    I would avoid granite or stone as it does get hard. Any wood should sound better. Mine are acrylic.
    audiothesis.com/
    Cabling: Wireworld
    Hmm mm there is a guy that works acrylic not far from me, can ck prices. Probably mdf 3/4" might do the job.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Mike ReeterMike Reeter Posts: 3,297
    I utilized Butcher Blocks/Cutting Boards for my Stands and made a Base for them. Pretty simple stuff. I haven't gotten around to Spiking them though.
    SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
    That's a nice look.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
Howdy, Stranger!
