Black Hole 5?
Seems to be out of stock or at least as hard to find as a good bottle of Pappy Van Winkle 23? Has this been discontinued by the manufacturer or does anyone have a good source other than Sonic Craft / Parts Express?
Took a 9-month break from playing with audio to get relocated and now it's time to finish updating all my Polk gems.
Working on the total rebuild of my second pair of 1.2TL big boys and the BH5 is the missing link to putting it all back together. So far I've completed a 2B (TL), 3.1 and a 1.2 and this stuff is amazing. I have sheets of Sonic Barrier and No-Rez but would love to stick with the BH5 in the SDA's.
Obligatory work-in-process pic (cabinet sealed, rings installed):
Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
    F1nut Posts: 49,801
    It's still available, but in smaller sheets and for a lot more money. As of now Sonic Craft and PE are no longer stocking it.
  • ken brydson
    ken brydson Posts: 8,650
    Next to the black paint...
  • RobbyKY
    RobbyKY Posts: 117
    Thanks Jessie.
    Is that the 12x18 size? Speaker City had that size listed on their website for ~$70(!) but I got a fault when I tried to order from there last week. Was acting like all was good right up until I hit the submit order button. Maybe they're just out for now as well? That was the last place to come up in a Google search that seemed to have some in stock? Ran through all the "authorized" dealers from the ORCA site to no avail.......
  • westmassguy
    westmassguy Posts: 6,850
    The 1 1/4" Sonic Barrier is nearly as good, for a third the price.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    Toolfan66 Posts: 16,906
    I think I got the last sheet of BH5 from Sonicraft a few weeks ago, I don’t think they will carry it anymore..
    pitdogg2 Posts: 24,577
    edited January 2018
    You, jesse and I
    They found 3 in the back room and Jesse and I jumped in it. If i had the cash i would bought 2 :)
    I believe Jeff or Elliot told me the same thing. As the supplier has changed the size and composition of it and they didn't feel it was worth the cost.
  • verb
    verb Posts: 10,176
    Toolfan66 wrote: »
    I seen that on Sonicraft last week ... Should've pulled the trigger !!!
  • RobbyKY
    RobbyKY Posts: 117
    Sounds like I'm a day late and a dollar short on the old school BH5. If the going opinion is the new stuff is sub-par, think I'll just use up my stock of Sonic Barrier. I've got some left-over BH5 and half sheet of No-Rez but not in the mood to play mix and match and then wind up redoing the cabinets. Can I assume similar size of the SB will yield similar results as the BH5? I remember reading a much older post by Larry I believe where too much gave poor results. Got more than enough of the SB to complete the 1.2's and then move on to the 3.1's. Can't thank everyone on this site enough for all the help!
  • verb
    verb Posts: 10,176
    Thanks David. Just ordered a sheet.
  • verb
    verb Posts: 10,176
    RobbyKY wrote: »
    Are you willing to part with your BH5? I’m doing a set of 1C’s.
    VR3 Posts: 28,038
    No rez is as good if not better. Made by gr research
    F1nut Posts: 49,801
    RobbyKY wrote: »
    Thanks Jessie.
    That's it.
  • RobbyKY
    RobbyKY Posts: 117
    Verb,
    I would if I can locate the rest of it.
    I was also using it for my #4 Vice in the rear inside wheel wells of this beast to tame the drone from the Nitto mud tires. Between the BH5 and lots of Dynamat, this thing became almost normal at highway speeds. When we moved, whatever I have left over got packed with the garage stuff but there's probably only enough to fit behind the tweeters in a 1C. The garage here in Texas is still a no man's land of boxes......
    You, jesse and I
    I split mine in half with Brian so he had some for his 2B's..
  • verb
    verb Posts: 10,176
    RobbyKY wrote: »
    Verb,
    No worries. My basement is the same way as we moved in October. Thanks!!!
    audioluvr Posts: 5,434
    I used the 1 1/4" Sonic Barrier from PE for my 1C's. I'm very pleased with the results.
    EndersShadow Posts: 17,533
    Black Hole... its the new Black Paint!
  • sbb2112
    sbb2112 Posts: 134
    I used the sonic barrier on my sda srs’s too and am happy with the results
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    Viking64 Posts: 6,687
    Well, I guess I'm lucky I got mine when I did. :p
  • TheChemist
    TheChemist Posts: 13
    edited January 2018
    RobbyKY wrote: »
    Thanks Jessie.
    I just bought some from there. $99 delivered but I live in Bush Alaska. Yeah, it is spendy. I had the same problem ordering and called them. I am finishing up my SDA2-B's, have the right tweet to install and wouldn't you know, the frame is ever so slightly too large. Going to spend some quality time with an Exacto knife.
    Westmassguy was very helpful in getting mine together, and patient too.
  • [Deleted User]
    I have about half a sheet of BH 5 left over from when it was sold in roughly 24" x 26" sheets. Can get exact measurements of what I have if anyone is serious about buying it.
  • verb
    verb Posts: 10,176
    Slapaho wrote: »
    I'll take it!!!
  • verb
    verb Posts: 10,176
    Black Hole 5 in the house! Enough to do my 1C's. Thanks @Slapaho !
    verb wrote: »
    It looks like you have a new vacuum tube. How does that sound with the rest of your system?
  • verb
    verb Posts: 10,176
    Very funny. My office, and repository for other junk. Sounds terrible BTW, even after years of burn in!
    edited February 2018
    verb wrote: »
    Try moving that BH5 a few inches to the West and it should suddenly sound great in there. :p
    If that doesn't work, you could always try some spikes.
    That appears to be a whole sheet. Looks bigger than a half sheet from the picture .....
    Hard to tell but that's killer
  • verb
    verb Posts: 10,176
    12" x 23.5" in size. The edges are all pristine (no cut marks) so I believe it came that way.
    Nope its been cut. I recommend a bandsaw, but a table saw works as well.
  • verb
    verb Posts: 10,176
    Allright @pitdogg2 you made me drag my arse down into the basement. :smiley: It does appear that it was cut, albeit a very nice cut! Looks like @slapaho used a tablesaw or similar. Very clean edges. I'll be doing the same on this piece.
