Hankering for Larry's Spikes
verb
Looking for some spikes to secure the 1C. Got carpet in the basement, short pile.
I seen some of the images of the spikes that Larry has made. Beauteous !!! Sadly, I have not heard of any future production runs on those
Decent reviews of the Dayton 2-Piece spikes in this forum. I like the idea of a 2-piece design and have the ability to level the speaker cabinet if needed.
And as always, I missed out on the smokin deal @Toolfan66 on those spikes back in June !!!
http://www.daytonaudio.com/index.php/dss4-g-gold-speaker-spike-set-4-pcs.html
Just for the record. Uh, no, I will not use the below per @lightman1 recommendation.
Do the 1c have a threaded T-nut now? Those at parts express are metric and will not work in the T-nut. I just bought some exactly like those. I have it bookmarked at work. I'll send a link if you like
No T-Nut now, but I was thinking about using them on my new bases. The originals were just glued and stapled.
I noticed the kit comes with a threaded insert (H-Nut). Anyone use those?
Sure please send link. Thanks!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I've gotta say, reading this thread's title via "New Posts" and sans context kinda had me a little worried.
@mhardy6647 you've been in the "gutter" thread a bit too long ...Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I have never done a run of spikes to sell, but after I made some stainless ones, I let go of a couple sets of my brass ones..
I have no plans to ever do a run of them.. -
Dang. Thanks for letting me down easy ... BAM !!!
Those nuts IMO suck. I will most certainly send you a link
nothing to see here, move along
Post edited by msg onI disabled signatures. -
Back in 1991, TBS used to air episodes of "The Beverly Hillbillies". They had an ad that said: "Jethro. Everybody has a hankerin' for him, but only TBS has a heapin' helpin' of him."
Teach me how to edit a post with nothing Scott.
Look closer Ivan.
"nothing to see here, move along"
President of Club Polk -
On a phone i can only get so close Jesse.
lol
Only so much i can see and do on a 4" screen
https://meniscusaudio.com/product/long-mirror-image-pts-gold/
Now you will get a discount for buying 8 I believe it works to 56.00 for those above and less for those below.
Look around the site, I bought these because I had the smaller points at home so if they were too tall I could switch them out.
https://meniscusaudio.com/product/mirror-image-pts-gold/
On past speakers I drilled a 1/4" hole through the bottom of the speaker. I then used a 1/4" fender washer under a the 1/4" grade 5 or 8 bolt head. smaller hole and nothing to come out and get tight as needed.
choose your path carefully. PM me if needed -
Thanks @pitdogg2 !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
