A friend just gave me (gratis) a pair of SDA1's :-)
Threshold400A
Newbie here. A friend (original owner) just gave me (gratis) a pair of SDA1's :-) They have the vertical tweeters. They are oiled walnut tops and bottoms and black cloth on the front and sides. I have not yet hooked them up to my Threshold 400A so want to ask about the so-called 'frozen' magnet issue. How can I determine whether these units suffer from any 'frozen' magnet issues. I do not want to try to drive the speakers if any of the magnets are damaged and if doing so will damage the woofers or systems. Also, if I need to purchase any new woofer drivers what is the contact point at Polk (Tel #?) Thanks !
Best Answer
Push on your mid-woofer cones gently and see if they push in and come back.
If they do that, you're good till you glue them down later.
Do you have the connecting cable ?
Your Threshold Amp. . I don't know if it's common ground or not. Others will chime in to let you know about that issue.Most people just listen to music and watch movies. I EXPERIENCE them.
Answers
Thanks, Tony. I do have the blade/pin cable
Maybe it's discussed deep down in this link. I got tired of looking at a lot of reviews and comments after a while. Don't hook that amp up until you get the common ground issue answered.
https://forum.audiogon.com/discussions/review-threshold-400a-amplifierMost people just listen to music and watch movies. I EXPERIENCE them. -
If the drivers are good/not frozen and the amps common ground issue hasn't been answered don't hook up the interconnect/SDA cable. You can safely use a non-common ground amplifier as long as that cable isn't connected. The speakers will just lack the SDA effect."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Nice friend!! Congrats!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Of interest:
http://www.diyaudio.com/forums/solid-state/284607-threshold-400a-bias-issue.html
Of more interest (see post 10): Nelson Pass himself says the 400A *is* a common ground amp:
http://www.diyaudio.com/forums/pass-labs/285958-threshold-400a-bias-issue-yes.htmlJay
@agfrost, Great Links! That was some great reading on a Threshold 400a amp and some insight by the man, NELSON PASS, himself.
Common Ground amp, for sure.Most people just listen to music and watch movies. I EXPERIENCE them.
