Got a call from 611?? Anyone else??
vmaxer
vmaxer Posts: 5,116
edited January 2018 in The Clubhouse
Weird, haven’t answered them. Any ideas?
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
  • verb
    verb Posts: 10,176
  • vmaxer
    vmaxer Posts: 5,116
    It’s weird, what I posted is all that showed. Not as an area code?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • verb
    verb Posts: 10,176
    More information:
    https://www.shouldianswer.com/phone-number/611
    Scammers for sure.
    Viking64 Posts: 6,687
    Don't answer. It is used by various scammers/hackers. Somehow they can "exploit your missed call screen" and do bad things.
  • vmaxer
    vmaxer Posts: 5,116
    I typically don’t answer any calls that I don’t recognize. No message, no call back.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • machone
    machone Posts: 1,475
    ^^^^^^ And I block the number
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • soundfreak1
    soundfreak1 Posts: 3,387
    611 on my mobile is the service # for T mobile.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • vmaxer
    vmaxer Posts: 5,116
    Yes, but I got a call from that number. Got another on Sunday??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • soundfreak1
    I get them from time to time for updates but they are marked from T Mobile.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    My rule is if I don't recognize it I don't call it back if they don't leave a message I don't call him back somebody I don't want to hear from I don't call him back then I blocked her number
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Jimbo18
    Jimbo18 Posts: 2,314
    edited January 2018
    Never got 611 but we get a lot of calls that try to look like they are from our area code, but are proceeded by a 1- . It can't be both local and long distance. In any event, like others here, if I don't recognize it, I don't pick up.
    I also signed up for nomorobo and that stops a lot of robot calls from ringing a second time.
  • verb
    verb Posts: 10,176
    Jimbo18 wrote: »
    Never heard of nomorobo - thanks i may give em a try !!!
  • Jimbo18
    Nomorobo is free for VOIP but it's a couple dollars a month for a cell phone.
    If you have VOIP, your internet provider has to allow Nomorobo (I think most do). Easy to set up and it's a one time thing.
    For VOIP, the phone rings once with you and also with Nomorobo. If it's on their lists of robot callers, and they have thousands listed, they hang up for you and it never rings a second time.
