Csi A6 Centre Channel Not Working
Accidentally touched a usb cable to one of the speaker jacks and suddenly no sound from centre channel. Is their a fuse in the centre channel, if not what can I do.
  • deronb1
    deronb1 Posts: 5,021
    There is not. Hopefully you didnt blow a channel in your AVR
  • 071863
    071863 Posts: 2
    I noticed the amp had shut down at the same time. The next morning I turned the amp back on, put the speaker cable back into the centre channel and it worked fine.
    tonyb Posts: 32,906
    You probably tripped a protection circuit in the AVR. Shutting it down for a period of time resets it. Don't do that again, make sure all your gear is off before moving cables around. Consider yourself lucky this time you caused no damage. Go play the lottery. :)
