new electrical panel / new circuit for stereo - advice?
I have an old house, and we are in the process of putting in a new electrical panel.
When we are doing the panel, I am running 2 new circuits for my stereo. My understanding, from what I have read, is to run a circuit for the amplifier, and one for all the other components, which run through a power conditioner.
I am planning on running 10/2 wire, one run for the amp, one for the components. I have read a few articles.....
but any other advice people can give? I am doing the wiring myself, so the cost is just the parts / components.
  • ken brydsonken brydson Posts: 6,625
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • gmcmangmcman Posts: 886
    I would recommend using a generator ready panel if you are going through all that labor. I did, and the peace of mind is beyond worth it. Also makes it easy if the wife needs to get everything going.
    Best part is you can power any circuit in the panel instead of a select few...if the genny is capable naturally.
  • rpf65rpf65 Posts: 1,494
    Don't go cheap on the plugs.
  • jolson72jolson72 Posts: 46
    gmcman: we have a woodstove, so i'm not worried about a generator backup. worst case scenario: we heat the house with wood for a few days. thanks, however.
    rpf65: meaning the wall outlet plugs, correct?
  • kharp1kharp1 Posts: 1,654
    jolson72 wrote: »
    That's all good until you're without power for a week, like we were her in Louisville a few years ago, and you have no hot water, or refrigerator/freezer. Also happened in late August/September with a wind storm. Or, in the case of Houston, or, other natural disaster where you're without electricity for longer than a week. It can happen.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • txcoastal1txcoastal1 Posts: 8,640
    You take whorebaths
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
    I take "crack whorebaths"!
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    thanks for the tips on generators. i don't know if that was the focus of my post, but i appreciate the deviation. any more tips on the actual post topic?
    The only reason I suggested a gen ready panel, is that you save a HUGE amount of labor from the gate. You will basically be installing the same item with the addition of a mechanical interlock on the first two circuits...you can add everything else later...inlet box, generator, etc.
    Replacing a 200A main panel is a very laborious task you only want to do once, including permits and all associated coordination with the poco.
    However if that's not you're interest then no worries....figure I would throw that out before you start.
    gmcman, i do appreciate it. not something i have thought of, but again, thanks!
  • MrBuhlMrBuhl Posts: 2,038
    edited January 8
    Not skimping on plugs is an excellent suggestion - even if you just get hospital grade good gripping plugs you will be happier for the few extra dollars. I ended using MIT Z Duplex outlets in mine and I'm happy with them.
    VA 2 Channel , McCormack DNA 0.5 (SMc Gold) Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Toobs Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, VPI Nomad Turntable w/Ortofon 2M Bronze, MIT AVt3 Speaker & RCA Cables, Pangea & Signal Cable MP power
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Dodd 50W Dual Mono EL34 Amp
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Bottlehead Foreplay (modded)
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
  • mhardy6647mhardy6647 Posts: 15,615
    gmcman wrote: »
    Yup - the big handle :)
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
  • Viking64Viking64 Posts: 1,060
    *receptacles
Howdy, Stranger!
