Warm up?
I have a PC that essentially has not been turned off for ten years and it is still kicking. Should I leave my audio stuff on all of the time and if not what are the most important components to warm up before playing? Asking for a friend.
  • hochpt21
    hochpt21 Posts: 5,423
    I leave my solid state gear in all the time. I turn on my tubes only when I want to listen.
  • machone
    machone Posts: 1,471
    I leave my PC/power supply on all the time. The rest I turn on as needed usually an hour in advance.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • cfrizz
    cfrizz Posts: 13,415
    My pc is on all the time, it will put itself into sleep mode after 30 minutes if not in use.
    My audio gear goes off when I'm done for the night, most of it goes into standby mode with the exception of my Polk sub which I leave on since the standby mode has always been flaky and won't wake when it should.
  • BlueFox
    BlueFox Posts: 15,251
    I leave my preamp and file player in the stereo on. Nothing in the HT is always on. My home PC gets turned on every few months or so. My work laptop is on while at work or home, but off during travel to and fro. My iPads and phone are always on. And my brain churns 24/7. :)
    Viking64 Posts: 6,646
    My power conditioner and PC are on 24/7. Everything else is as needed. If I want to turn my gear on, I just talk dirty to it.
  • delkal
    delkal Posts: 764
    If your PC has not been off for 10 years.......Back up your files. NOW!
  • kharp1
    kharp1 Posts: 3,453
    PowerPlant stays on 24/7 as does the Butler amp. Any SS amp stays on at all times. Everything else as needed.
  • ptrooper
    ptrooper Posts: 501
    edited January 2018
    My power conditioner , voltage regulator and 4 x power amps stay on 24/7
  • afterburnt
    afterburnt Posts: 7,892
    do yall warm up transports and DAC's?
  • kharp1
    kharp1 Posts: 3,453
    When I was using an outboard DAC I left it on most of the time. It ran a little warm, so, if I knew I wasn't going to be spending much time in front of the system I would shut it off, but, mostly it was on. The Marantz turns itself off or I'd leave it on all the time. There may be a way to bypass that, but, I'm too lazy to look in the manual and see.
  • 11tsteve
    11tsteve Posts: 1,166
    My NAD pre and the Keces DAC are always on. When I had the McCormack, that srated on as well. My current Class A space heater prohibits that, so its an hour warm up before serious listening.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    Clipdat Posts: 12,557
    Nice idea to keep solid state power amp turned on, but what about turn on/off transients from your tube pre? Pops, noises etc.
    Goes against the standard turn on order of source -> pre -> amp. And then off order of amp -> pre -> source.
  • mikeyb128
    mikeyb128 Posts: 2,885
    DSkip wrote: »
    The only thing I turn off is my tube gear.
    I do this as well. Even though Cary recommends leaving its tube preamp on at all times. I turn it on Thursday night so it’s ready for Friday beer time. It gets shut off Sunday or Monday for the work week.
    2 channel:
    Theater:
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    I leave SS amps on all the time and never have pop when turning the Joule pre on or off.
    tonyb Posts: 32,902
    My Joule Pre stays in standby mode, dac is always on, everything else is off.
  • kharp1
    kharp1 Posts: 3,453
    tonyb wrote: »
    I like the standby mode on the Joule, keeps it from coming up from a cold start. Also like the design of the Butler...even though there are tubes, it can stay on 24/7.
    tonyb Posts: 32,902
    kharp1 wrote: »
    tonyb wrote: »
    The Butler design is unique in that way, where the tube life is extended beyond what normal tubes would have if left on 24/7. My guess is you have another 10 years before having to have those tubes replaced because I didn't leave it on 24/7. Matter of fact, it only saw a couple hours a week of operation.
    SCompRacer Posts: 8,350
    edited January 2018
    It would cost me ~$800 a year if I kept my amp on 24/365, so I don't.
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited January 2018
    ^^I think Sal could power his leaf for a year with that much juice.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
