Integrated turned on side
kevhed72kevhed72 Posts: 3,113
I scored a Yamaha rs500 for a song on Ebay for the deck speakers and genera listening Boston Acoustics speakers. Anyway, any issues with placing the integrated like this out of the way:
  • HermitismHermitism Posts: 1,502
    I know nothing about this, but will the heat from your furnace cause any issues, since that vent is right there? I use a couple clear plastic vent deflectors here at the house to change the air direction.
    2.0 - Marantz NA8005 | Polk LSiM703 | PS Audio: Duet, Power Port Classic | Wireworld Equinox 7 IC | Sanus UF30 | OC703 Panels
    6.1 - Pio Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | Monster HTS 5000 | DCF124BW SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate HDMI x2 | M850SW | PS Audio Power Port Classics | OC703 Panels
  • NightfallNightfall Posts: 7,341
    edited January 4
    I would bet it wouldn't keep as cool because the heat sinks are probably on the sides so now you have a heatsink between the floor and the side that can't get rid of it's heat as heat rises and now its heat flow is covered by components.
    Would this be enough of an issue to cause problems? I don't know. Maybe you got it cheap enough to where "who cares?" Comes into play.
    | Front - Dynaudio Emit M20 | Center - N/A | Rear - Polk Monitor 4 | Sub - N/A |
    | AVR - Yamaha Aventage RX-A1020 | Preamp - Dared MC-7P | Amp - B&K Reference 4420 |
    | Turntable - Yamaha PX-3 | Cartridge - Dynavector DV-20X2H | Digital Source - AURALiC Aries Mini |
    | TV - LG 60" 4K | Gaming - Xbox One - PS3 - New 3DS XL - Nvidia Shield TV |
    This body holding me reminds me of my own mortality
    Embrace this moment, remember, we are eternal
    All this pain is an illusion
  • mhardy6647mhardy6647 Posts: 16,919
    edited January 4
    Sideways per se shouldn't be a problem unless there are any air vents on the side of the unit. If so, even that shouldn't be a problem if they can breathe. E.g., Raise the unit up a few inches on, say, a wire rack type of shelf. Put the P/S (transformer) side down - for best stability. :|
    The unit is designed to cool by convection (from bottom to top) but, with adequate ventilation will likely be OK on its side (especially if run conservatively).
    You can always run it for an hour or so (ahem, conservatively) and just kind of feel it all over (whoo! baby!) and see if there are any untoward hot spots.
    Plus, it wouldn't hurt to see if it says anything in the owner's manual about running it sideways ;)
    Heck, maybe an e-mail to customer support might not be a total waste of time(!?).
    I thoroughly concur with the post above re: the HVAC duct -- be wary of that if it's heat as well as (or as opposed to) A/C.
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    Can't you lay it flat beside the heat vent with the controls facing the couch?
    Maybe put it on a block of wood or something to get it off the floor and further away from the vent?
    edited January 4
    ^^^ or hockey pucks. I have become a big fan of hockey pucks as spacers, feet, etc.
  • kevhed72kevhed72 Posts: 3,113
    Great Sideways movie tie-in....one of my favorites. I didnt think about the heat issues....fortunately, or unfortunately this particular winter season, we are on electric heat pumps- which got nothin on the Midwestern gas fired furnaces of my youth. The heat generated by an electric heat pump is luke warm at best. Ill give it a go and see how hot the top gets. Being next to 2 two single pane glass windows might keep it cool enough.
  • F1nutF1nut Posts: 39,295
    As Doc points out, it cools by convection, which isn't going to happen on its side.
  • nbrowsernbrowser Posts: 7,726
    I would imagine it'd be ok...if used for low volume background music...that said if you're wanting to crank it up, I'd personally sit it the normal way.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • FestYboyFestYboy Posts: 1,960
    You could always ventilate the side...
    The other problem could be, of course, a variation on the dreaded Taco Neck Syndrome.
    edited January 4
  • ClipdatClipdat Posts: 2,683
    Don't do it!
    Got Dayens?
    Alan_r wrote: »
    My passion is for the music, my hobby is how I listen to it.
  • steveinazsteveinaz Posts: 18,097
    Would you want to be turned on your side all day? Huh? Wouldja?
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8TC; DH Labs D-75 | AC Power: Panamax M5300-PM
  • lightman1lightman1 Posts: 9,265
    The electrons will leak out.
    steveinaz wrote: »
    There's probably a completely inappropriate yet supremely witty response, somewhere, to that query.
  • Viking64Viking64 Posts: 2,157
    Get some scrap 2 x 6's and make a shelf with them between the window sill and the arm of the chair/couch or just put the damn thing out on the deck.
  • tonybtonyb Posts: 28,701
    Kev, the guys are right, don't do that. Your going to shorten the lifespan of that piece, unless you don't give a hoot. Just build a small shelf that goes over that floor duct, done. Heck, a couple bricks and a flat piece of wood or granite tile would work too.
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • motorstereomotorstereo Posts: 733
    How often are you going to be using it? I'm thinking it'll be just fine on it's side for occasional weekend deck music. My deck receiver has been living under much harsher circumstances than that for a few years now and it still work fine. Even in yesterdays bombtornado or whatever they hyped it to be it fired right up snowflakes and all.
Howdy, Stranger!
