SDA grill badge removal "how's it done"
Ok fellas I'm looking at replacing my grill cloth on my 2Bs, yep we had a cat years ago. As I look at the badge it has a single post with a metal clip down in a recess, how do I remove it without damage or breaking the post? Any help would be much appreciated Happy New Year.
Cheers
Randy
Yamaha RXA1030, Yamaha CD
Polk SDA2btl highly modded
PolkM7b peerless
Polk CS350 LS x2
Polk m5jr
Kimber 8TC
Sony 55" Bravia
Wish list Polk SRS 2 or 2.3 TL, SVS sub, Parasound amp
  • Tony MTony M Posts: 3,752
    Can you get us a Pic ?
    Most people just listen to music and watch movies . I am glad to be a part of a select group that tries to take our auditory and visual senses to a higher level: we EXPERIENCE them.... GOT SDA?... Got TFM ?
  • Take some small needle nose pliers and peel back the two tabs that are pressed against the post. Or anything small that can pry those tabs back.
    After it's out push those tabs back down. So it'll grab when you push it back on.
    The Night is Dark and Full of Terrors
  • I see what you mean, I'll try realeasing the spring tabs. Thank you
    PolkM7b peerless
    Polk CS350 LS x2
    Polk m5jr
    Kimber 8TC
    Sony 55" Bravia
    I thought I had done that before but I wasn't quite sure the label pin situation was the same.
    Hope that's does the trick. ;)
Howdy, Stranger!
