Bed Room Rig.
Well finally get to enjoy the system. Got a week off from work. But will start traveling again soon.
Simple
Decco 65
Onkyo C-S5VL
Klipsch Heresy
I have read on a few sties claiming the Heresy don't produce good bass. Well I don't now what kind of bass they are looking for but this do very good. Is all about placement. Like a good business is all about location, location, location.
The Onkyo will be use as a transport and I will try to Dynamat the hell out it. Enjoy
Cheers
Rey
AVR-Onkyo709
AMP- Parasound 2125, Adcom 585
Mains for HT and some Music- RTi12s
Main for Music only- Linn Keilidh or Usher V-601 and SDA 1C
PreAmp for Music: Cary AE-3
Rear- RT150
Center-CSi5
Sub-Rythmik audio F25
Player- Oppo BDP-103
Bedroom rig:
Pionner Elite VSX-30...Onkyo CS-5VL SACD Player....Polk Audio LS70
  • ClipdatClipdat Posts: 3,578
    I have that same CD that's sitting on the table.
    Would there be any advantage to getting some simple stands like this to get the speakers off the floor and closer to ear level?
    Got Dayens?
  • schwarcwschwarcw Posts: 7,148
    Yes, IMO most speakers that size would sound better on those stands and off the floor, the tweeter should be close to ear height in your listening position.
    Carl
  • IrrenhausIrrenhaus Posts: 732
    edited February 15
    [/quote]
    Thanks for the advice, what stands are those?
    I was looking at this ones but the may a bit overkill for the Klipsch's
    http://shop.mapleshadestore.com/15x18-Speaker-Plinths-with-4-thick-base-Natural-Maple/productinfo/PL15X18CL4/
    The chair I have in the room have a lower sitting position.
    Cheers
    AVR-Onkyo709
    Rear- RT150
    Center-CSi5
    Bedroom rig:
  • DSkipDSkip Posts: 14,511
    Those are Sound Anchor. Simple, but expensive.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    I found them here: https://www.ebay.com/itm/Pair-of-Harbeth-Super-HL5-Plus-or-earlier-HL5-Speaker-Stands-MADE-IN-USA/152902159454
    Irrenhaus wrote: »
    Got Dayens?
  • tonybtonyb Posts: 29,082
    I've heard.... putting the Klipsch's on stands may give you a loss in the lower end. I would say before investing in stands, use something else as a makeshift to get them up and then evaluate the sound.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    edited February 16
    wrong place.
    Cheers
    AVR-Onkyo709
    Rear- RT150
    Center-CSi5
    Bedroom rig:
Howdy, Stranger!
