Off topic 4k internet connection
Just got 4k Samsung. After tv identities my network, it wants password, but before last digit is entered, it starts to try to connect. Samsung was no help. Do I need to shorten my password. Now 12 digits.
Very frustrating. Thanks for any help. Oh, it also shows spectrum as internet carrier, it is att.
  • Emlyn
    Emlyn Posts: 4,369
    Could be the TV is picking up a neighbor's WiFi connection and trying to connect with that. I live in a single family home but the TV can pick up weak signals from three other houses.
    Viking64 Posts: 6,679
    Emlyn's post above makes a lot of sense based on your symptoms. If your TV has Wi-Fi, try disabling that in the menu and hard-wire the TV directly to your modem.
    pitdogg2 Posts: 24,560
    Does the TV have a wifi WPS? Push the router WPS buttom as the TV WPS is on if it's like a phone if should see it and no password needs to be input. They will talk to each other and sync up.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    The interface shows that it is connecting to my router. I've just wired it to my amazon fire, which is on an hdmi switcher for now. This I bypass the internet and apps on the TV....I'd just like to see if the TV Inet and apps work better.
    My modem is in on a different floor. The work around works, but wastes part of what I paid for (even if I don't end up using it)...thanks
  • jeremymarcinko
    I bought a Samsung 4K last month. No issues connecting my WiFi. My password is 10 digits, if that helps.
