Anthem mca325
Hello, buddy of mine pulled the trigger on Mca 325 new to match his anthem avr. He has it on an open shelf and is driving A9’s with the matching centre. When playing at moderate to high levels say -15 , should the amp be so hot you can’t hold your hand on it. Tks for looking.
Rec rm vm30 micro pro 3000 akai 2 channel. ht pioneer sc57 sunfire 5 x 200 panasonic 65" plasma lsim 705’s , 706c.
garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • ClipdatClipdat Posts: 4,718
    Contact Anthem technical support?
    Got Dayens?
  • Their support is really good. At least they have been very helpful to me.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk Signature S60's;Cables: Wireworld Eclipse IC; Audioquest Big Sur IC; LAT International speaker cables; PS Audio AC-3 power cords, all into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; SDA2BTL's, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage.
    Political memes posted as fact and accepted as fact, are sign language of the ignorant, for the ignorant
    tonyb said " but even socialists can do a good thing here and there
  • jimsvmjimsvm Posts: 292
    My mistack for not mentioning , it is ultra crisp and clean and blistering loud . My bad. Opps cheers
    Glad the sound is on point, but the running temp would make me a little worried.
    I would take the chassis temperature with an infrared thermometer and then contact Anthem technical support to determine if it is within safe/expected operating temps.
    jimsvm wrote: »
    Got Dayens?
  • DaveHoDaveHo Posts: 1,967
    Could be normal. My Aragon amp runs around 125 deg F when up to temp. Perfectly normal given the high bias of the design.
Howdy, Stranger!
