Difference Between BFA and Banana?
So I keep seeing this "BFA Style" connector.
What the heck does BFA stand for? and how is it different from a Banana connector?
It seems like the BFA Style is this banana connector with the squiggly/cutout in it, and a regular banana connector has the spring mechanism all around, or in the 4 quadrants?
  • txcoastal1txcoastal1 Posts: 9,602
    edited December 2017
    British Federation of Audio...created by the Eurocrats due to safety concerns
    So that you don't do sumtin'stupid like plug your audio connector into the euro electrical socket
    Banana plugs are actually illegal in Europe, hence the reason that when you receive amps, they may have those red plug caps stuffed in the the amp terminals
  • msgmsg Posts: 4,037
    Ahhhhh, gotcha.
    Hehe, yeah, I read something about that.
    How does this prevent someone from sticking it in one of those sockets?
  • pitdogg2pitdogg2 Posts: 9,813
    Right Scott I'd like to know that as well.
    The marketing has always sold them as more contact surface.
    I guess because of the resemblance of the nanner euro plug :/
  • dannylightningdannylightning Posts: 233
    from what i have seen the banannas listed as BFA do not have the little springy things like regular banana plugs do
    here is a BFA vs regular banana, pretty sure that is the difference between the two so i would say you are probably correct just adding the photo so anyone who reads it sees what we are talking about
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
  • KingratKingrat Posts: 48
    All I want are some banana plugs like I used to be able to get where you can use huge wire size, and crimp them and solder them easily, and don't cost a ridiculous amount of money. Last solder ones I got barely have any solder cup in them and a 14 gauge wire is about as big as it wants to take, so I've been using the Monoprice screw clamp ones and after tightening them up, using my big old foot long soldering iron to solder them. I have some old ones someplace, can't find them after I moved that took 8 gauge cables without problems, and a 60 watt iron was fine.
    Cable atheist: They're just trying to get your money like a TV preacher!
    Vinyl system: I'm long done with the snap, crackle, and pop.
  • afterburntafterburnt Posts: 4,388
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
    Well, um, I guess I should have added "That don't cost an insane amount of money each" Almost $18 for four?? I don't think so, but thanks. When I can buy other ones that are usable, that are much nicer looking and appear to be a lot more solid, for much less, I'll pass. The description of them on the AQ page is pretty funny though, unless you believe in cable and connector magic.
  • F1nutF1nut Posts: 39,603
    What I believe in is putting worthless posters where they belong....poof
    Oh my, I blasphemed..So sorry.
  • gp4jesusgp4jesus Posts: 1,132
    Kingrat wrote: »
    All I want are some banana plugs like I used to be able to get where you can use huge wire size, and crimp them and solder them easily, and don't cost a ridiculous amount of money. Last solder ones I got barely have any solder cup in them and a 14 gauge wire is about as big as it wants to take...
    I use the plugs in the upper part of DL’s post all throughout my system. W/a little patience, 8 gauge will fit.
    You can find a 12 pack, look-a-like, gold plated brass on eBay, under $13 shipped. Copy and paste...
    VOSO-24K-Gold-Plated-Speaker-Cable-Wire-Connector-4mm-Banana-Plug
    ...should get you there
    Tony
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
    Thanks, I actually found some that were like what I've had in the past:
    https://www.parts-express.com/gold-plated-crimp-on-banana-plug-16-pcs--091-350
    They don't take as large a wire as the ones I have in a box someplace, but they will take 12 gauge and that's big enough and they look deep enough to crimp without much chance of ruining them. The problem with the two piece screw ones is that if you crimp them, the screw on part won't fit, and if you don't, you need to use the giant soldering iron that is a pain to use, due to it taking forever to heat up, and it weighs a ton and keeps trying to slide out of my holder due to the stiff cord. I only normally use it for PL-259 radio antenna plugs. It works great for them. The new banana plugs will solder up fine with my much nicer to use 60W iron.
    edited April 11
    Kingrat: I can’t argue w/your sentiment. The AQ & VOSO plugs - same material, same contact principle, but $4.50 versus $1.08 a piece. C’mo-o-on!
    I read the AQ product description. I don’t get your point.
    Kingrat wrote: »
    ...unless you believe in cable and connector magic.
    Tony
    gp4jesus wrote: »
    Kingrat wrote: »
    Tony
    The new ones worked great, I made up 2 sets of cables last night one pair about 7 feet long each, and another pair about 20 feet long. The sleeve is more than long enough and it crimped easily and soldered fine with my 60 watt iron. I'm buying some more of them, and putting them into my recently purchased plug/components holders so they wont go missing again.
    You don't get my point about the AQ (and other cables)? Did you read my sig?
    Kingrat wrote: »
    you don't get my point about the AQ (and other cables)? Did you read my sig?
    The mobile app doesn’t allow signatures through. I switched to full site - I get it.
    You find my lack of faith disturbing?
  • steveinazsteveinaz Posts: 18,203
    edited May 1
    You'll get more surface area contact with a BFA, has the whole barrel makes contact, not just the raised portion of a standard banana. Will it make any difference? I doubt it.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; DH Labs D-75 | AC Power: Panamax M5300-PM
  • LegenderLegender Posts: 443
    non-believers....everything makes a difference.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • mlistens03mlistens03 Posts: 986
    I personally believe that cables do make a difference, and banana plugs probably do too, but I’m not gonna spend money on banana plugs because it is literally like a 2 centimeter connection point. It can make a difference, but I can’t imagine the money would be worth that little of one.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • verbverb Posts: 2,559
    mlistens03 wrote: »
    Connectors are all about a good connection. And maintaining that connection under all circumstances. Like a chain, only as strong as the weakest link. Lots of info out there. Yeah there is a point of diminishing returns, IMO, but take a look. There's a price point for everybody! Another journey! FWIW. :smile:
    2CH: Polk SDA 1C's, Micro Seiki MB14 TT, Rotel 1580 Pre, Marantz CD6006 CDP, Carver TX8 Tuner, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    verb wrote: »
    mlistens03 wrote: »
    sorry, I forgot to add IMO in there.
    but yes, I do know what you mean. but I meant for my INCREDIBLY low price point, its not a viable upgrade.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • Viking64Viking64 Posts: 2,531
    edited May 1
    Legender wrote: »
    Don't misunderstand my comment. I am a believer in cable differences, but I don't see how the little bit of difference in contact area would affect the tonal characteristics of a cable. Now, If I were designing a cable form the ground up, I'd go with BFA's simply because more surface area contact certainly doesn't hurt anything--but I wouldn't stress about it on a cable that only came with standard bananas.
    steveinaz wrote: »
    you just made the case for..,
    steveinaz wrote: »
    I do, especially connecting 4 ohm speaker due to the BFA’s lower resistance compared to the bananas
    steveinaz wrote: »
    I'd go with BFA's simply because more surface area contact certainly doesn't hurt anything--but I wouldn't stress about it...
    Every little bit counts more than you think. On a power cord thread one reply read (paraphrased) “better bass due to .47 lower voltage drop.” Makes sense to me! Hence why I have 8 gauge wire soldered all the way to my woofer’s driver tabs. Same for 10 gauge to my LCR mids; surrounds to follow.
    Not all banana plugs are created equal. The ones dannylighting posted are poorly designed and constructed with minimal contact area. Compare them to high quality banana plugs such as the ones from MIT and the differences become obvious. The MIT's have 6 springs with a solid center post connected to a solid dome tip. The outer surface is in contact with the center post and when the springs are compressed they are too. Therefore, the MIT banana has considerably more mass, which means better conductivity.
    In addition, I measured the inside diameter of a Cardas binding post at .160 and the outside diameter of the MIT banana at .160 before and after the springs. With the springs compressed they also measure .160. Obviously, the banana is ever so slightly smaller than the post hole, but that's as accurate as I was able to measure. The difference is extremely small as evidenced by the super tight fit of the MIT banana plugs.
    Furthermore, the solid dome tip bottoms out in the binding post meaning it is in full contact. Compared to the BFA type plugs there is no doubt that a high quality banana not only has greater mass, it also has greater contact area.
    Note: for some damn reason (vanilla) all of a sudden today I am not able to post photos from my device on this site. I can everywhere else, so I know it's vanilla related. Maybe one of you guys can post a pic of the MIT banana plugs for me.
    Boy it's tiny :p
    I recently discovered my box of IMHO, failed, banana plugs. Most of them are no crimp/no solder types, but there are some that only take 14 gauge and up wire, or have only a tiny little wire socket that makes them very difficult to use I crimp and solder mine, and have a huge collection of short speaker cables going back about about 30 years when I converted my speakers over to bananas. I should probably sell the 40 or so Nakamichi (fakes?) I have just so someone else can maybe use them.
    The ones I use look pretty much identical to the big pic above. Crimp and solder, and never worry about them again.
Howdy, Stranger!
