What is the best way to paint the grills on in wall RC85i speakers?
What is the best way to paint the grills on in wall RC85i speakers? I going to paint them to match the wall color. A Crutchfield video said poke or stipple the grills with a brush but I want to be sure. Thanks
Answers
  • KennethSwaugerKennethSwauger Moderator Posts: 6,462
    Hello,
    It was always recommended to remove the scrim backing cloth and use an aerosol spray paint to avoid blocking the grille's holes.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • FestYboyFestYboy Posts: 2,447
    Thin the paint, use a stiff foam roller. light layers is key. As Ken states, the scrim should be removed no matter the application technique.
Howdy, Stranger!
