rt70 should be facing which way?
Hi, I'm new to installing any in-ceiling speaker, and to be honest these were very easy to install, but I did run into an issue, which way should they be facing? Should the tiny tweeters be facing the listener? I know they can't be physically moved, but at least I can aim them on a general direction.
Thanks,
Rafael
  • rooftop59rooftop59 Posts: 4,278
    Yes, ideally you want the tweeters aimed at the listener. That is why you can move them, so that at least the higher frequencies will be directed at the listener.
    Welcome to club Polk! Stick around, and enjoy the new speakers.
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
  • tonybtonyb Posts: 29,206
    Generally speaking, yes....face the tweeters towards your listening position. You may have to experiment a bit, depending on how you have them setup in relation to your listening position. If you can get the tweeters to aim about 2 ft past your head it may be better. In other words, you form a triangle with you, and the front left and right speakers, aim the tweeters so they cross about 2 ft past your head so your listening position is inside that triangle slightly. Experiment a bit....
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • Thank you guys so much, I'll experiment, but at least now I have a point of reference.
Howdy, Stranger!
