Sound bar will only allow me to turn up volume?! Please help!
indyfelonindyfelon Posts: 6
edited December 2017 in Troubleshooting
Also, I have also attempted to sync my tv remote in thinking surly it will allow to turn it down once I by pass the physical volume button... nothing... it will only allow me to turn the volume up.
Post edited by KennethSwauger on
Answers
  • DaveHoDaveHo Posts: 1,960
    Which sound bar? That would help.
  • treitz3treitz3 Posts: 12,511
    Have you tried a hard reset?
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
  • Polk Audio - MagniFi Soundbar System with 7" Wireless Active Subwoofer -
  • Not yet. Will look in to trying that this evening.
    Mods, if you see this....can you remove the "Answered" from the thread? Thanks.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,614
    Hello,
    Usually this kind of problem results from using a cable/satellite remote to program the soundbar. The first thing to do is erase the stored instructions by putting the bar in the standby mode (red LED) then press and hold the "learn" button for a couple of second until the LED blinks. Now the bar should only respond to the Polk remote. Then use your TV remote to program the bar, once it has learned this it will respond to the cable/satellite remote.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Kenneth, no luck with trying to unlearn. What's is odd is that even from the actually unit you cannot turn the volumn down, just up. Any other suggestions?
    I believe it is time to contact Polk's CS department on Monday at: 1-800-377-7655 select option 1 and have the serial number available. They'll take care of it.
  • Will do, and thanks for your help!
    You're welcome!
  • Hi Indy I have the exact same issue my volume down button on the bar itself will not work every other button functions properly on the unit. The Polk remote is able to turn volume down but the physical button on the bar cannot. Seems the physical button is broken to me, I called customer service but they are closed on the weekend, were they able to resolve your issue?
    I want to be able to learn the volume down function on my other remotes but cannot since the physical button won't work to be able to be selected to learn. I can learn every other function as the other buttons all work.
Howdy, Stranger!
