Armacell question
I'm going to need to open one of my SDA's, sounds like the XO has come loose and I need to repair. When I pull the PR, the Armacell will be fully compressed, and it does not expand back out again. Do I need to apply new Armacell and re-compress? Or can I just re-use the existing flattened seal? I'm thinking the only way to get a good seal is to re-do it, and re-compress over several days.
  • xschopxschop Posts: 868
    Renew and re-torque often.
  • pitdogg2pitdogg2 Posts: 10,845
    I would not see why you couldn't reuse it. why would that be any different than factory gaskets? As long as it is not tore I'd think you could reuse.
  • nspindelnspindel Posts: 5,288
    Factory gaskets have a bit of thickness to them. They're foam and compress a bit as you tighten down. But the Armacell is different. Armacell compresses to the point of being paper thin, and doesn't expand back at all when you remove the driver. The only reason I ask is I've done it before, and it's a royal pain to remove the existing layer. Could just go over it I suppose, but I'd be inclined to remove it.
  • nooshinjohnnooshinjohn Posts: 18,237
    There is no need to replace it.
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Krell Evolution 525a CD Player, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
  • Viking64Viking64 Posts: 3,285
    All of the original gaskets on my 2.3TL's were paper-thin when I pulled the drivers, and they didn't expand at all, even overnight.
  • F1nutF1nut Posts: 40,390
    Viking64 wrote: »
    ^ THIS ^
    The gaskets are supposed to be paper thin because you want the driver in maximum contact with the bezel.
    Understood. Not questioning whether the seal should compress to be paper thin, I know this is what's supposed to happen. I'm simply asking whether or not it's recommended to replace the seal and start from scratch if you remove the driver, or if the existing paper thin Armacell seal can be retained and just screwed back in?
  • FestYboyFestYboy Posts: 2,783
    Never double gasket anything that sees pressure.
    nspindel wrote: »
    Reuse if not torn.
  • muncybobmuncybob Posts: 1,872
    FestYboy wrote: »
    Yep, forgot to remove the oil filter gasket on my old Chevy once and applied the new gasket over it...what a mess!
    Yep, my name really is Bob.
    Parasound HCA1500, Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Oppo BDP93, "upgraded" Polk SDA 2B.
    Ok, reuse it is. Certainly is easier! Thanks folks.
Howdy, Stranger!
