Defintivie BP30 Crossover Mod
VR3
This one is a little different but similar to my norm. Was fun to do something a little different though.
My favorite part of that picture is the Autobot in the background!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Haha you got me, I have a small amount of my collection left
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My recent mod with Clairty caps with bypass caps and Path Audio resistors. Wanted to try making them all out of acrylic. Very happy with the result. Thanks for the help with the inductors specs VR3.
turned out awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
be careful with acrylic when you go to secure them as acrylic will literally shear like glass. i used the material a long time ago and moved away when i discovered a whole build splitting in half at a mounting point.
Lexan is a good alternative which is borderline unbreakable- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It’s pretty easy to crack or chip. But I was pretty happy with the results. Too bad they are at the bottom of the speakers.Post edited by AndreE on
Thanks for the diagram VR3. Very happy with the sound. Bass is tight and crisp. Crossover is pretty much the same as the BP10B, pic at the bottom. Wish I did change the inductors as well on the BP10BPost edited by AndreE on
Agree they turned out awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Those are pretty beautiful!!
Thank you but it was all based off others ideas. I wanted to post to share and say thanks for the ideas. I picked up the Bp30’s for 400 and thought it would be fun. Truth is you can get alot of bang for the buck tweeting but it can get out of hand. But hobbies are. 🙃
