Soundbar 3000 original remote not working
New battery installed correctly. Not working. Original remote for Soundbar 3000 does not control the soundbar. Otherwise, I did train my cable provider remote to work, but the sound is too loud. When the cable remote sound is turned all the way down, to zero (per display on TV, Soundbar volume still very loud. Which is why I wanted to get oringinal remote to work.
I read somewhere that I can get the cable TV remote to be trained to the Soundbar mute. Correct?
But main problem is non-functioning original remote.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,260
    Welcome to Polk's forum. Place the bar in the standby mode, the LED will be red. Then push and hold the "learn" button until the LED blinks. This will erase all stored memory and the bar should only respond to the Polk remote. If you've changed the battery and it doesn't control the bar telephone 1-800-377-7655 select option 1 and have the unit's serial number available.
    Regards, Ken
    "That which can be asserted without evidence, can be dismissed without evidence."
    — Christopher Hitchens
  • jmbenekejmbeneke Posts: 1
    I'm having the same issues. I have an IR repeater for other devices and it indicates the remote is broadcasting but the Surroundbar 3000 isn't responding despite clearing the stored memory as Ken stated. I had this exact issue last year and got a new remote but the issue has resurfaced again. After clearing the stored memory I tried to use the Learn function with the factory remote without any luck. I guess I'll contact Polk and see what they can do for me. Odd issue and a little frustrating as I would love to use the original remote.
    Regards, JB
Howdy, Stranger!
