Speaker port noise bass trap
I bought a tall set of SVS rear ported towers a while back and because of my lack of real estate in my listening room, have to keep the speakers about 6" from the rear plaster wall.
This creates unwanted boominess from those twin ports.
I tried the supplied foam bungs and got some relief by using just one set, but the bass sounded unatural to me, like something was missing.
I had a set of beige carpet pads that I'd picked up at Home depot to place on my L shaped workbench to lay guitars on and was curious if they might quell the port reflections off of the wall by placing them behind the SVS's and they did.
When I mentioned this to a friend of mine in the recording buisness, he told me that they would work even better if I could get some air space behind the carpet.
I ended up using a couple of 1/2" thick slats, which I drilled three hole through and affixed the top of each carpet to the wall, through the slats, so that they draped downward.
This gave a small space between.
Damn, if that didn't tighten up my bass !
It killed the boom enough, where I could even drop the sub's volume, because it didn't have to mask the boom coming off of my walls anymore.
The carpets match the wall color, so they don't stick out visually.
Total cost for this solved problem..........about 10 bucks.
  • F1nutF1nut Posts: 39,806
    Nice tip, thanks!
  • Polkaguy58Polkaguy58 Posts: 285
    edited November 2017
    I should add, that my buddy said that an inch of space would be better, but 1/2" slats is what I had at the moment and didn't want to have to drive thicker, longer screws through double that depth.
    As I understand it, the low frequencies are supposed to pass through the material, reflect off of the wall and dissipate against the back wall of the material.
    I'm considering making some out of acoustic foam, placed within a picture frame and maybe hung from hooks behind the speaker.
  • gp4jesusgp4jesus Posts: 1,137
    Awesome how the simple, inexpensive "tricks" work well.
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
Howdy, Stranger!
