SRS 3.1 interconnect cable
aegis43
First day on the forum, so I already know I'm going to sound dumb and I apologize. I'm an audiofile noob. Can anyone point me to where I can get a new, or good used pin blade interconnect cable that is 30-feet, ish?
Best Answer
Wow, 30 feet ? Not even gonna ask.
Try Douglas connections, he's a member here and sells speaker wire, he can probably hook you up.HT SYSTEM-
Answers
Thanks, Tony. I'll find him and ask.
That pin blade end is going to be VERY HARD to find. Most here have converted to speakon's connection for that very reason. In the past some made use of RCA plugs that they trimmed off the outside gripper petals so the inner shaft could get deeper into the pin part. The blade part was not ever needed except for support of the cable, UNLESS you were using mono block type of amps then it served as the common ground part, from what I remember. The reason many moved away from the RCA was that in some cases it never made a good connection.
Doug may have something I cannot say so it is worth a try.
Good luck.. -
We don't have any of the pin blade connectors, so can't make copy of the original cable. We can make the speakon connector cable though.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Is the blade even necessary? Until I got my Dreadnought, with new cables, my SDA cable was nothing more than a length of wire with RCA connectors with the outside connectors cut off of the RCAThe difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Correct on the blade Travis. Did you get a good tight fit with the RCA's
