Auris BluMe?
Just curious if anyone in the forum has tried out the Auris BluMe Bluetooth receiver? It is advertised as having a high end DAC to improve SQ. That said just wondering how streaming music this way would compare to running a hard wired music server.
____________________________________________________________ polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS SVS PB13 Ultra x 2Pass Labs X1, Marantz 7704, Sunfire Signature Cinema Grande 400, ADCOM 7807, Panasonic UB420, Sony SCD-C333ES, EPSON Pro Cinema 6050
  • PSOVLSK
    PSOVLSK Posts: 5,021
    The title of this thread sure seems like locker room talk to me:)
    pitdogg2 Posts: 24,475
    PSOVLSK wrote: »
    And she was gooood :p
    Ok back to regular scheduled programming
  • soundfreak1
    soundfreak1 Posts: 3,374
    Thought he was bragging at first.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    txcoastal1 Posts: 13,124
    edited November 2017
    Looks cool...
    Back ground music streaming vs an actual 2channel and DAC????
    Or are you wanting to use the library of remote PC???
  • dpowell
    dpowell Posts: 3,050
    For the times I'm not doing real serious listening but still want streamed or mp3 music to not sound compressed. Also curious if the Bluetooth signal itself compresses audio which then makes having a high end DAC on the other end not as worthwhile since it would be converting an already degraded audio signal.
    Then I'd give it a shot especially if you can return it if you no likey
  • ken brydson
    ken brydson Posts: 8,638
    PSOVLSK wrote: »
    Sorry, couldn't help myself...
    tonyb Posts: 32,902
    dpowell wrote: »
    You know our saying.....garbage in, garbage out. No dac will take a t u r d and turn it into a gold bar.
    That said, you can make MP3 sound less compressed and you don't need a high end dac, just a good one. Look for dacs with a Burr Brown chip, AKM chip, as to my ears they sound a bit more analog than the Sabres and Wolfson chips. Granted, a chip isn't all that dictates the final sound, but I think in the price range your looking at, the chip should be more heavily considered.
    MP3 is a degraded file, Bluetooth isn't the best either, so your starting with 2 strikes, and depending on what your playing it on, could also degrade the sound further. Everything matters in the chain, a decent dac with some decent cables, played on decent gear can make MP3 sound listenable.
    The Auris does use a chip made by AKM, so that's a plus in my book, and since you can return it if you don't like it, give it a whirl and see. Not an expensive product anyway.
