Marantz sr-6011.....Polk S60.......can I use 4 channels to power 2 towers?
MackMurder
Ok so the marantz 9.2 channel amp has like 110 wrms @8 ohms per channel
I know the S60s can be bi-wired or bi-amped
Bi amp means more power from 2 different amps. Adds better sound and more detailed?
My question is could I use two front channels for the lows and 2 surround channels for the highs? For a total of 220 wrms per tower? Or will that **** up my amp.and or speakers
Home theater:
-Samsung 65" Q7F Qled - XboxOneX
-Marantz 9.2 Channel SR6011
-Tech 1200's
-Polk S60 Towers
Car Audio:
-4500 wrms cresendo mono block amp
-Fi SP4 v2 18" sub (3000 wrms)
-hertz 1000watt 4 channel
-hertz mille component speakers
-hertz spl 10" 600 wrms sub
-370amp mechman alternator
-2xs power 3300 amp batteries
-2/0 gauge ofc everything
-Tech 1200's
-Polk S60 Towers
Car Audio:
It doesn't work like that. You cannot bi-amp from a piece of audio gear that has a single shared power supply as does every AVR made. Pure marketing hype.....otherwise known as BS.Political Correctness'.........defined
President of Club Polk -
awsome thanks F1. Bi wiring would be the option for me tho correct? With some good wire as opposed to the stock material Polk provides?Home theater:
-Tech 1200's
-Polk S60 Towers
Car Audio:
-2/0 gauge ofc everything -
Bi-wiring, running 2 sets of cables, from 2 different out puts, to each individual's binding post on your speakers, can be done with most AVR's. Most people hear no difference from using this method or a single cable run.
More people hear a difference when they remove the factory jumpers and replace it with jumpers made with good quality wire. -
Yes, just do this. Ideally try to make he jumpers from the same wire as the cable. Blue jeans cable has some nice affordable options.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Done and doneHome theater:
-Tech 1200's
-Polk S60 Towers
Car Audio:
