Help identifying.
cmy330go
Wondering if these are 1.2 or 1.2TL? Thanks!
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
2 CH
Also... Assuming they are in decent shape, problem free, and have the cable, is $1500 a fair price?HT
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Gonna go out on a limb: 1.2... TL have different tweets
That's what I'm thinking too. Looks like first gen tweeters to me.
Lets see interconnect B/b. Or p/b.
Thanks for the input. So not worth pursuing at that price?HT
2 CH
They are definitely 1.2's, NOT TL's. IMO, $1,500 is a steep price since you will almost definitely want to replace all 8 tweeters, with RD0-194's as the SL2000's will make your ears bleed; That will be pricey to do, and make the price more than they are worth, IMO.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
On the other hand you won't find a pair of non-SDA speakers that can do what those will at any price.Political Correctness'.........defined
President of Club Polk -
Very true Jesse.
If the OP wants to shell out money for the new RD0-194's and the $1,500 then go for it.
I think 1,500 is a bit high. 1,200 is a fair price if they are in good shape."Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn -
They could be 1st gen SRS's and unless I missed it, the OP did not state what type of interconnect socket they have. If it's pin/blade they are 1.2's and can be converted to 1.2TL's. If it's blade/blade, they are 1st generation SRS's and cannot be converted to TL.
+1 to what F1 stated.
SDA SRS 1.2TL's
SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
SDA 2B TL's w/RD0198-1's
Yaqin MC-30L integrated tube amp
Yaqin MS-20L integrated tube amp -
I'd pay the lightman 2.15 and then a couple canadian nickles...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
michaeljhsda2 wrote: »They could be 1st gen SRS's and unless I missed it, the OP did not state what type of interconnect socket they have. If it's pin/blade they are 1.2's and can be converted to 1.2TL's. If it's blade/blade, they are 1st generation SRS's and cannot be converted to TL.
Very good point. I forgot about the SRS's.
That's all the photos that the seller posted. In the listing the only detail he gave was that they were 1.2s, but judging by the photos, and the rest of the post, I question how much he knows about what he has. I'll start probing for some more info, and pics. Maybe I can talk him down a bit.
I've know for ages that the SDAs are held if high regard, but I've never had the fortune of hearing any, and they rarely come up for sale in this area. So if I could pick these up for the right price, I'd love to give them a try.HT
2 CH
Have the seller take a picture of the interconnect, that will clear up some confusion.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
RandyCroissant wrote: »Have the seller take a picture of the interconnect, that will clear up some confusion.
Those in the know can also count the screws on the XO plate and tell between SRS and 1.2. I however am not that guy. -
Early 1.2s used the leftover SRS front plates.Home Theater/2 Channel:
dhsspeakerservice.com/ -
And then there is that....
Back to the interconnect socket or ask that he pull some drivers -
No need to pull drivers. Just need to know what kind of interconnect socket it is.SDA SRS 1.2TL's
I'd say they are SRS's judging by the warning on the back of the speaker about common ground amps only. 1.2's don't have that warning I believe. The interconnect will tell the truth however."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Please tell me that's not a valve stem cap on the one binding post.HT
2 CH
Looks like it's blade/blade so they are first-generation SRS's, not 1.2's.SDA SRS 1.2TL's
The real question is, how often did he change the air out inside the cabs?I disabled signatures. -
Scott those can get very brittle, so as you see they are using bare wire. That can when tightened too tight cause the nut to get oval which can with brittle plastic split the nut. One also when using bare wire tighten enough to push the ring on the binding post connector to make good contact with the face of the binding post or it just makes very little contact with the inside surface of the ring.
Actually that fix should work. And you have to give the guy some credit, who would ever guess the threads would be the same
